TechTalk
After reading various comments comparing Hasselblad XCD lenses to Leica lenses, I decided to let the lenses speak for themselves with some comparisons of the XCD 35-75 mm zoom lens to some lenses from Leica. Since there are no directly comparable lens lines by both format size and camera type, I compared lenses designed for nearly identical format size (XCD and S) and I also compared two mirrorless lens designs of different format (XCD and SL). I noted that there were no direct comparisons in both camera type and format for Leica and Hasselblad.
I chose the XCD zoom to provide a bit of a handicap to Hasselblad, as zoom lenses are generally not expected to compare well to prime lenses. I also chose to compare the XCD zoom to an SL prime lens, with comparable angle of view, to provide a double handicap to Hasselblad of a zoom lens made for a larger format. Some comments followed those comparisons which took some exception to them.
The approximate image diagonals for different formats: 24 x 36 mm = 43 mm / 30 x 45 mm = 54 mm — 33 x 44 mm = 55 mm / 40 x 53.4 mm = 67 mm
When comparing lenses designed for different formats, there is generally an advantage in image quality for a smaller format lens. A fact to be noted is, that along with the angle of coverage being different, the angle of view will also be different for lenses of the same focal length, but designed for different formats. The difference in angle of view should be accounted for when comparing lenses of different formats.
That's why when I compared the the XCD 35-75 mm zoom at 35 mm (77° angle of view) to the comparable Leica SL lens, I chose the SL 28 mm (75.4°angle of view) rather than the SL 35 mm (63.4° angle of view). Had I done otherwise, someone might have implied that I lacked a basic understanding of optics or was making an amateur mistake.
There is no "like for like comparison" to be had if you're comparing Leica and Hasselblad lenses. I made note of that fact earlier...It is just not a like for like comparison to compare mirrorless to mirror based lenses.
As for comparisons, apples, and oranges; for now, if someone wishes to compare Leica and Hasselblad XCD lenses, the comparison is either going to be between lenses made for mirrorless and SLR cameras of similar sensor size or comparison between lenses made for different format sizes...
You could, but they're lenses designed for different formats. You could also compare an XCD lens to a Leica SL lens (I did), but they're also lenses designed for different formats. Now, what you should do when comparing lenses, that I'll leave to you. But, you will not have a "like for like comparison" when comparing lenses designed for different formats.You should compare H with S system.
...Comparing Hasselblad XCD lenses to smaller format Leica SL lenses would be an interesting challenge for Hasselblad; as generally speaking, lenses for larger formats will be at a disadvantage when compared to smaller format lenses. Similarly, zoom lenses are typically at a disadvantage when compared to prime lenses. Lenses covering larger format sizes or providing more than one focal length present additional design and production challenges.
Lens designs for mirrorless and SLR cameras are different, but not necessarily "completely different". How different will vary depending primarily on the type of design and focal length. Two designs for comparable focal lengths could be very different or minimally different.Anyone with a basic understanding of optics knows that performance is completely different when you are close to the sensor plane and can skip the whole mirror box. That's almost an amateur mistake to be honest.
