Getting up to speed with ultra high ress scans
fgpm
Hi i have been shooting film for a while along side of digital and after a lots rolls and sheets i think it's time to build a set up for ultra high ress scans to produce large prints and pull everything from film i theorized a few options and id need to discuss them
1) drum scanner
Simply the best- no sensor in between straight from the grain to the digital file in full res without interpolation but from waht i have seen unless there are other option than buying refurbished scanner from the few that are selling them the price are off charts, and learningis curve is though,is also true that once i get great results from it could consider charging for the service of the scans and it would be an investment set in stone but id rather avoid to spend 20-30k+€ plus training
2)Reprographic set up with my current camera
i have an hasselbad x2d and i could build a reprographic system with it , but i don't know from where i should start, to match at least on paper the resultion of a drum scanner i would need to consitently stich 2-4 immages for 6x6 negatives and 3-6 immages for 6x8-6x9( it would get even worse with large format) negatives so id need to set up eveything to consitently move the negative or the camera the X and Y axis with out with out introducing misallingment or miss focus , on the lens side aside from the hasselbad macro option i don't know where to start the only repro lens i have heard of are the alpa/rodenstock ones the lens would need to be so good to avoid any a bottleneck to the sensor , even with the best set up it would be the cheapest set up but im not still shure if the cmos sensor of the x2d is up to the task of repro and i would get color interpolated immages ( hasselblad might build in the future a multi shoot x2d but at the moment who know with 100mp full rgb data but at the moment is unclear )
Build a repro system with a digital back
Same questions as above but with extra question of which Back should i get , the best one would be would probably the multishoot hasselbad 400c (100mp full color data with the extra option of 400mp 6 shoots) but getting it new is out or question and didn't find anyone used for a good price , the other more viable options are iq3100 iq380 and h6-100c, i also wondered if an achromatic(mainly iq100a and iq260A) back could be use to procude full rgb accurate color scans by shooting each scan 3 times while changing filter(which filter ?) in between and merge them in photoshop (a technicolor trichirome procedure)
Let me know you opnions about which route i should pursuit and how i could therefore reach the goal im trying to achieve
felix5616
Look for a Creo IQ2 or IQ3 scanner. The IQ2 scans its entire bed at a true 4300dpi, the IQ3 scans up to 5500 dpi
Hello,
If you do it yourself, do not go with a drum scanner. Interface from 1999-2000 and you'll have to use a Mac from then. The process is so long.
If you need scans of your film, we do it here at Aperture Archival. www.aperturearchival.com. We have the highest resolution digitization system in the industry with a Phase One IQ4 150 Digitial back on a DT RCam camera housing. Blows drum scans away and the emulsion is never touched or oiled like a drum is. There is no comparison as time to digitize as it is instant capture.
We work with working pros and digitize everything from 35mm up to 16x20 negatives and glass plates. Take a look at our site. If we can help at all, please reach out with a description of your project. Keep in mind that we don't do projects smaller than 10 sheets at a time.
If you are interested in investing in a full system yourself, then look at Digitial Transitions in NY. They are the leader in cultural heritage work.
Cheers.
