Ben,Darr
I completely understand you.
I still use my Hasselblad V lenses on my Phase One XF and my Fuji GFX.
Normally my clients don't appreciate the the difference, when I use these lenses.
When I use them, I do it only for my preferences, for portraits with environment. It's often more time consuming (manual focus etc.)...
Since I shoot more and more video, sharpness has a new facet.
...and I love the 5 bladed bokeh of the HB-V lenses.
BTW, the 40 IF and the 150 CFi have almost no focus breathing - great lenses for medium format video with GFX 100.
What about focus breathing with the CF 60?
The 80 is breathing too much, for me.
I never had to worry about focus breathing as I do not do video, but I know where commercial photography is headed.
I read a little online about this, and here is a quote that I thought would get me out of setting up and looking through the 60 (LOL) ...
from: https://www.howtogeek.com/780326/what-is-lens-focus-breathing/
I found all the Hasselblad CF60/3.5 data I have does not give a “maximum reproduction ratio” or “reproduction ratio" number.If you’re looking at the specs online, look for the “maximum magnification” number. You might also see it written as “maximum reproduction ratio” or “reproduction ratio.” The higher that number is, the less focus breathing the lens will have.
Maybe someone else can find it.
I did setup my 501cm and placed the CFi 60/3.5 on it. The camera was on a tripod in a far corner of the studio (it is now night in Florida). I had a printed box about 3 feet (1 meter) in front to one side and focused on that as my near object. Then I focused 44 feet (13.4 meters) away on the front door's doorknob. Not infinity, but some distance. To my eyes, there was a small change on the sides, but nothing like some other lenses I have used, and the center appeared not to change other than going a little in and out of focus (wide angle on 6x6). I tried the CFi 100/3.5 and got similar results.
Will that help you? Maybe not, but to me, there was no noticeable shift in focal length, just a small amount on the sides, and that was easily seen because the studio wall on my right side has brick framed with wood inside of drywall (different shooting backgrounds). If the wall was all drywall, I doubt I would have noticed at all.
Best to you,
Darr
