dchew
The L60 / L75 geared heads are relatively small, light and solid for a geared head. Their Achilles heel has been range of adjustment. The 75 is limited to 15 degrees, L60 only 10. This isn't quite as bad as it sounds because you can shorten one or two legs of the tripod to get an addition 20 degrees or so. If that isn't enough, you can add a leveling base like the RRS TA-2U for an additional 20 degrees.
That is plenty of adjustment for normal shots, but it still doesn't allow for shooting straight down for leaves, rocks or other close encounters. I've been trying to come up with other gadgets or adapters that would enable shooting down (or up I guess). So far, this is the best thing I've found in my several boxes of idle pieces-parts that I've gathered over the years. It is from RRS; I think it's the L-bracket from an A7r. I don't know for sure. It is stamped "BA7-L, which makes me think it is from the Sony:
It weighs 50 grams and seems pretty solid. Here is how it connects the STC to the L60, but it would work on just about any camera:
It is not the best solution, but it works and is what I have sitting around. I wonder if anyone else has solved this in a more elegant way, or if there is a product out there designed to do this that doesn't weigh too much?
Dave
Dave
