I should mention that there are (3) adapters available from Cambo for Hasselblad V lenses and Mamiya/Phase One/Schneider BR lenses that fit the Cambo WRS bodies. There are (2) adapters for the Hasselblad lenses, one that has a built-in cocking mechanism. This opens up strobe use as the leaf shutter of the lens can be in play and also moving objects, and the less expensive version has no cocking mechanism, so the Electronic Shutter of your digital back would have to be in play (no, or limited strobe, and nothing large moving in the scene).
The Mamiya adapter fits legacy Mamiya lenses, but also the newer Phase One/Schneider BR variants (no aperture control, however on any lenses without a physical aperture control ring).
$1,259 - Cambo Hasselblad V Lens Adapter with Shutter Activator
https://digitalback.com/collections/cambo-wide-rs/products/cambo-wrs-hvsa-lens-plate-with-shutter-activation
$744 - Cambo Hasselblad V Lens Adapter (no Shutter Activator)
$744 - Cambo Mamiya/Phase/Schneider Lens Adapter (no aperture control without physical aperture control ring)
https://digitalback.com/collections/cambo-wide-rs/products/cambo-wrs-m645-lensplate-with-mamiya-645-bayonet-mount
You have shift on all these lenses - not a ton, but a respectable amount (most in the range of 7mm - 9mm).
Steve Hendrix/CI
