No, I don't have it, those are pictures from http://dc.watch.impress.co.jp/:ROTFL:
You had it already?
you don't want it?
it IS around f4 at 20mm.
the 7-14 will also be an f4 I think.
this 9-18 is good on the G1 though (at least, I think so).
You had it already?
you don't want it?
Hi ScottTo see what I mean by shots that I think would be tough to get with the G1 and its present lenses, see the "fun with M8" series that I just uploaded to the M8 forum next door.
scott
Refer to the earlier posts on this subject (EVF focusing). More accurate than any RF focusing. The speed depends on practice. The EVF focusing should not be compared to GG focusing. It is even better than the split screen.That's a pretty quick turnaround. It even looks like there wasn't time for a sip or two between the two pictures. One small correction. I would have needed a 35/1.4 to get the same working angle with a 4/3 imager. (I have a 35/2, so that might have worked.) Focusing on these guys' faces, even at 3-10 m, is a constant struggle. Can you really focus with the EVF as fast as with a rangefinder? I used to be pretty fast with my Nikon F's 105/2.5 using the split image screen, but never with a ground glass, which is how the EVF looks.
regards,
scott
HI ScottRefer to the earlier posts on this subject (EVF focusing). More accurate than any RF focusing. The speed depends on practice. The EVF focusing should not be compared to GG focusing. It is even better than the split screen.
BTW, Monza and Jono- why are you folks posting shots of the 4/3rds adapter here? Just curious.
Don't ignore Scott . . . it can be very dangerous (I think he is a purple belt at Judo).Jono, Breezed past that.
Don't worry - he's a sensible guy, and anyway, you've only to look at what he already owns to realise that resistance is useless!He is in denial, as far as I can make out.
It'll be fun to try . . . but I'm more interested to see how the 50mm f1.5 sonnar does on it . .. and the 75 'cron.BTW, Jono, your ZM 25 will be a good match for the G1 (through the M adapter, of course).
