ondebanks
My take on the difference between CCD and CMOS:
There is none. :lecture:
- Err, WHAT, Ray?![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
No, really. There is no inherent difference in what they do. Doped and biased silicon pixels trapping photoelectrons. That's it.
- Ah come off it, Ray! We can SEE the difference!
You can see differences alright - but they have nothing to do inherently with the underlying technology of CCD vs CMOS. Paul (wentbackward) identified many of the reasons above. Spectral response is the main one - a combination of front-of-sensor colour filtration, and photon absorption depth within the sensor. Both of these are at the whim of the designer, for both CCD and CMOS.
It so happens that some manufacturers dominate in making camera CCDs, some dominate in making CMOS, and they each have a typical way of doing these design aspects that influence colour; and therefore people have mistakenly associated one kind of colour response with CCDs and another (generally deemed inferior) kind with CMOS.
There are those who love the colour output from their Leicas (M8, M9, S, S2), or Pentax 645D, or 16/18/22/31/39/40/50 MP Hasselblads and Phase Ones; they may say it's because those cameras/backs use a CCD. Not quite! It's because they use a Kodak CCD. Same goes for all the the DALSA-chipped units. The secret sauce comes from the manufacturer, not whether it's a CCD. And then on top of that, you have how different integrators of the same sensor handle colour profiling, which is why some will prefer a Leaf back to a Phase back with the same DALSA sensor.
- But CMOS definitely has lower noise than CCDs, Ray! You often said it yourself!
Again, this is not an inherent property of the two kinds of device, but rather a consequence of engineering practicalities. Some early CMOS cameras and backs for photography, like the Leaf C-MOST and Kodak 14n/SLR-n, actually had worse readout noise than their CCD contemporaries. If you read a CCD out slowly enough, or employ EM-gain at the expense of dynamic range, it can be extremely low noise as well. Again, different engineering explains why Canons are noisy and have limited DR at low ISO (often worse on both counts than even older CCDs) while increasingly, Sonys (and Nikons, Pentaxes) have lower noise and high DR at low ISO, even though they're all CMOS.
- But...my CMOS camera gives me better shadow detail and worse highlight recovery and specular handling, than with my CCD camera. Explain that!
First, play fair: make sure you are using two cameras with very similar pixel sizes (a reasonable proxy for pixel full well capacity). If your CMOS camera is a DSLR/CSC and your CCD camera is an MFD unit, chances are that the CCD has larger pixels. And it's the area that matters - the square of the pixel width. So 5 microns CMOS might seem close enough to 6 microns CCD, but 25 square microns is a lot less than 36.
Now, underexpose your CMOS camera by about 1 stop. If you bracket a bit, you'll find an exposure where the highlights are about as good as the CCD, and the shadows have degraded but are still no worse than the CCD's.
You will probably have to add a further -1 stop underexposure to the CMOS camera for every stop above base ISO that you shoot the CCD, since most CCD units, especially MFD ones, fake higher ISO by simply underexposing, which gives naturally enough gives even better highlight recovery, since what were highlights slide down towards the mid-tones and the shadows are utterly foresaken.
- And the film-like quality and smooth highlight tonal gradations that people associate with CCDs? I suppose you have an answer for them, too?
I do. It goes back to the "high signal, high noise" nature of the typical CCD photographic capture. The typical CMOS capture OTOH has "moderate signal, low noise". (Again, I stress that what's typically engineered is not an indicator of absolute underlying performance capabilities). Plot signal to noise versus intensity (or Adams' zone scale) and the two representative curves cross over in a way which explains these visual effects. Manipulating these curves is essentially what software like DxO Filmpack does to create more film-like images from digital.
- Look, we all know that CMOS can do Live-view and Video and CCD does them poorly, if at all. That must count as a real difference?
It's only a difference in off-the-sensor routing of the signals. If you force* all the data from a CMOS sensor through a single serial pipeline like a CCD does, you'll find them no different in those regards. [* Why on earth you'd do that is not the point...I'm just saying that again it's not inherent to the sensor internals]
Ray....clicking "submit" and waiting for the :cussing:
- Err, WHAT, Ray?
