OK, since you brought it up...For that matter, the Zeiss 135 S-Planar Macro T* comes up a lot in connection with Hasselblad bellows, but I've not seen it discussed elsewhere. Is it still competitive to modern (non-Rodenstock) alternatives?
Thank you for your patience,
Matt
At one point I owned the following Zeiss-for-Hasselblad macro lenses: 4/120 Makro-Planar, 5.6/135 Makro-Planar (w/bellows), and 5.6/120 S-Planar. Performance, at least at magnifications up to 1:2 or so was roughly equivalent, with perhaps a slight edge to the S-Planar followed by the 4/120 and 5.6/135. Note that the bellows unit for the 135 is a bit kludgy; fine adjustments take a little futzing, but optically it's a fine lens.
You raise a question that I've been pondering while reading through this thread: how good is good enough when it comes to these home-brew scanning solutions? I would say that if you can resolve the grain structure of the negative, anything beyond would be overkill. Around 5 years ago I digitized some 6x6 negatives using the 4/120 Makro-Planar on a 501CM body + IQ160 60 Mp back. It was quite the contraption with the tripod head at some ridiculous angle and the negative on a fluorescent light box held down with glass from an old Omega 4x5 negative carrier. Alignment was done with a bubble level, so accuracy was iffy at best. I probably stopped the lens down further than I should have, but if I recall correctly, I could resolve the grain structure of the Plus-X negative. So, for 6x6 negatives or larger, it seems to me that the old Zeiss macro lenses are more than up to the task (might be a different story with 35mm negatives). YMMV, of course.
I've also been using these lenses for my various macro projects, with the 120 S-Planar over the past ~2 years as this is the one I decided to keep. While mostly in the 1:2 to 1:4 range, shot wide open on the IQ4 150 I've never detected any chromatic aberration. Examples can be found here.
Question for @JeffK: when you stitch to digitize 4x5 negs, do you move the negative or flat-stitch by shifting the back on your Alpa? I no longer bother using the stitching function in Photoshop when I flat stitch landscapes using my Cambo. Instead I just load the images into a stack, align them manually, and then brush out the overlapping edge on the top layer using a large brush set to minimum hardness. It's a bit slow but not unreasonable as long as throughput isn't an issue.
John
