Macbook Pro Mid 2012 incoming. Let's cross fingers it works![]()
yep, the mid2012 non-retina was the last one that you could easily replace SSD, memory or battery and is a great thing when you need to work with older backs.
Very similar to my setup for scanning film with a Sinar eVolution 75h (Soon, a jenoptik m22 as wellI have an old Imacon 848 scanner, which only has a Firewire 400 connection (besides SCSI...).
What I did is:
Just an idea on how things can integrate to each other.
- Bought an old Apple Mac Mini (2011) Core i5 2,3 GHz 256 GB SSD 16 GB for the crazy price of 160€.
- Hooked up the scanner to the Mac mini (via Firewire 400-to-800 adapter).
- Configured a shared folder on the Mac mini coming from my main Desktop Mac PC (Monterey).
- Controlling the mac mini via screen sharing directly by main Desktop mac (I didn't even connect a keyboard to the Mini
- Every scan (around 350-380GB) is directly saved to the shared folder. So, as soon as it is saved, I can open and edit it locally from my main PC with Photoshop).
What I did is:
I chose no network connection due to security concerns of such old hardware.
Digital backs are for relieving such fears !If you keep it clean and connected only inside your home network (no Internet) then there should not be any security concerns.
For the 848, it is a great scanner but every time I use it I'm in constant stress fearing about what will happen if a light bulb will die or something mechanical will break.![]()
Well, newer ones at leastDigital backs are for relieving such fears !
A few lower Mpix backs give more peace of mind than just one top modern….Well, newer ones at leastI fear for my Sinar gear all the time!
That's why I have two Sinars 54h, 75h and 86h.A few lower Mpix backs give more peace of mind than just one top modern….
It seem that Mac Mini and iMac both have a bit crippled firewire, not enough power, and most db users would have liked to use them.Update from the tethering side: I got by chance an active Firewire repeater (even the model phase recommended!), so now tethering via my Mac Mini is possible and works flawlessly. A lot nicer to use than the old Mac Pro which is loud and feels ancient!
The Macbook Pro also arrived, but no time for testing it yet.
Interesting, have not run into this issue with my Mini and Sinar gear at least.It seem that Mac Mini and iMac both have a bit crippled firewire, not enough power, and most db users would have liked to use them.
As I understand it the problems that arose lead to salespersons giving advice on always using firewire hubs. (Powered)Interesting, have not run into this issue with my Mini and Sinar gear at least.
