gmfotografie
i like this setup ... as i do a lot of architectural pictures i´m not that guy who is moving the ballhead a lot .... i´m the straight one... so i will try this solution ... with the tvc 24 :thumbup:
I don't mind being on the edge but that's a step too far for me. :facesmack:
Dave, that is really neat thinking. I was considering just a leveling base because of the low profile.Here is the the base (TA-2_LC) alone on top of the TVC-24-L. It really is amazing how light tripods are without a ball head:
Richard,My set up is ...
- Really Right Stuff (RRS) TFC-14 Series 1 Carbon Fiber Tripod - MFR # 13996.
- Really Right Stuff (RRS) BH-30 Ball Head with Mini Screw-Knob Clamp - MFR # BH-30 PRO.
- Hasselblad HATQCH (3043326) Tripod Quick Coupling.
- Arca-Swiss ARUCP38 Universal Camera Plate 3/8".
- Nikon AR-3 Shutter Release Cable.
- Artisan & Artist ACAM-302 Silk Cord for Hassleblad Cameras (Black).
The tripod and head have a combined weight of 1.332 kg.
Thanks, Matt.Bigger ones - so they'll work on my other heads.
--Matt
I don't use an SLR, but the Alpa has two RRS plates, one next to the grip and one on the "bottom" 90 degrees away so I can orient it rise/fall or shift.How do you flip your camera from horizontal to vertical position using cubes and geared heads? Tech cameras may have rotating backs, so that may not be an issue, but what about just using your SLRs?
L plates!
Do you guys dismount the camera, flip it and then remount it on the tripod? That's a pain especially with a heavy rig!I don't use an SLR, but the Alpa has two RRS plates, one next to the grip and one on the "bottom" 90 degrees away so I can orient it rise/fall or shift.
My Sony a7rII has a RRS L-plate.
Note even with the cube you can tilt it 90 degrees if you want.
Dave
Actually I much prefer rotating the camera vs flopping a ballhead over for two reasons: 1) I find it quicker, and 2) it is more stable sitting square on top of the head. I've done both and much prefer L-plates even on my ball heads. But you mention a heavy rig; I'm not sure about that because I don't have heavy rigs.Do you guys dismount the camera, flip it and then remount it on the tripod? That's a pain especially with a heavy rig!
Can you tilt the cube 90 degrees quickly or is it a matter of turning 3 or 4 screws?
