You could connect a Canon lens by combining a few different inexpensive adapters. You will still need a way to set the aperture on the lens before you mount it to the the camera since there will not be any electronic connection to control it.
EOS to M42 (cheaper option, but requires additional M42 to M65 adapter)
Thread: M42 1mm. It is just for macro shooting, it can NOT focus to infinity. No ROM connection on the adapter. Automatic diaphragm, auto-focusing,or any other functions will not operate correctly while using this adapter.
www.ebay.com
M42 to M65
- Modify lens purpose, focusing to infinity not available. - Female side: M42x1 screw thread. - Male side: M65x1 screw thread. - Heigth: 5.5mm. - Material: aluminium.
www.ebay.com
EOS to M65 (more expensive option, but does not require additional adapter)
Find many great new & used options and get the best deals for Canon EOS EF Camera Mount to M65 x 1mm Screw Adapter at the best online prices at eBay! Free shipping for many products!
www.ebay.com
M65 to HBLD V (the M65 thread will screw into this)
( height 7mm,screw thread height 5mm,Suitable for use with the Adjustable Focusing Helicoid). Useful for non-standard lens and bare optical block adaptations. Made of Anodized Aluminum in Black finish with high quality.
www.ebay.com
R Lens Board - Hasselblad V Bayonet
For Hasselblad V lenses Bayonet adapter lens board for Rm3di, RL3di, or Factum cameras only Requires 20.5 extension when used with a digital back Extension not required when using GFX 50R as the capture device For manual aperture control lenses only Bayonet mounts to the TUM helical, red dot to...
arca-swiss-usa.com
These pieces will at least connect the lens to the camera, but I haven't worked out the spacing to know if the thickness of these adapters will provide you with the distance needed for infinity focus. If you need more space between the lens and back then there are M65mm spacers that can be purchased to help you get the right distance. If you need less space between the lens and back then this approach won't work.
