That may be true, but I have been very satisfied and pleased with my HC35. Maybe I am not as discerning as I should be, but I print large and have never had a problem with resolution or for that matter any other technical issue. However, I would love to have the HCD28 even though I would lose some crop since I am using the H4D60.I'm sure others will jump in with more conclusive advice.
The HC 28 is unique in MF - if you have a large chip (H4d-50 or H4d-60), the results are spectacular - check out:
http://www.hasselbladdigitalforum.com/index.php/topic,1442.0.html
What what I've heard, the HC35 is not as sharp as it could be with modern high res backs, and is due for a replacement ala HC50 or HC 120.
I have the H4d-50, how do you think it would work with that back?I'm sure others will jump in with more conclusive advice.
The HC28 works very well with the H4D50 (I have this camera)I have the H4d-50, how do you think it would work with that back?
Thanks,
Greg
Hello GregI have the H4d-50, how do you think it would work with that back?
Thanks,
Greg
Quentin,Hello Greg
The 28mm is very sharp. I use it on H4D -50.
I dont own and have never used HC-35. However I did own a HC-50 which I replaced with the HC-50 II and appreciated the better resolution from the newer lens particulary at the edges of the frame. The original HC-50 looked ok until I saw how much better the MkII version was. If the same is true for the 35 then I suspect you will be happier with the 28.
Quentin
