and it works well ? what are the limitations ?No mechanical shutter in the body but a firmware update during the summer gave us a electronic shutter.
Hi,Hi Joe, it's the Kipon adaptor.
Looks like a Voigtlander Hyper-wide?Hi,
Is the lens to the right the Hasselblad x-pan's 30mm?
Best regards
I have tried the CV 15, the summilux 21, the elmarit 28, summilux 50, summicron 90, and macro elmar 90. All work fairly well, but roughly speaking only 80% of the picture is usable when you remove the dark corners. Rule of thumb, this means the lens will have effectively the same focal length. I have not tested all of the lenses thoroughly, but I noticed that longer focus lenses have less vignetting.Hi Ray
Please share some thoughts on your experiences with the Kippon adaptor and M lenses - I would appreciate them - in particular the WATE and any wides you have tried... I am looking to also buy the Nikon G adaptor so I can mount my Milvus and Otus lenses...
Pete
And yes, you need to use ES. I find this quite workable even hand-held unless you are shooting moving subjects. One issue, since the diaphragm is not closing and opening, there is no sound at all when a picture is taken.
I measured the diagonal excluding the vignetting and turns out to be about 80% of the total diagonal. So that should be ~40 megapixels.So roughly speaking the M type lenses will cover about 35-40 megapixels worth of chip. Any other issues apart from the vignetting?
Pete
There are disadvantages to the ES, but as you and others have noted, they're pretty overblown. In my prelim testing with ES and the X1D, "normal" handheld shooting (i.e. point camera and shoot it) worked just fine.I measured the diagonal excluding the vignetting and turns out to be about 80% of the total diagonal. So that should be ~40 megapixels.
As for other issues, I did not do yet a thorough test for all lenses that takes time, and will start working on it upon my return home next week. If any of the lenses I mentioned is of particular interest to you, let me know, I would start testing it first.
Coming back to ES, I read everywhere that you need a fixed subject and a tripod. I have done all my preliminary tests handheld, some of them included distant moving subjects, or tree leaves, and did not notice any problem. True it takes 0.3 seconds to get all the image scanned, but the image of a person that occupies 1/5 of the picture will be scanned in 1/16 th of a second, and if that person was walking, the image will not show much distortion. Tree leaves are also smaller and would occuppy a smaller portion of the image.
LOL, true that! But no worries, I'm ahead of the curve - just received my new iPhone X yesterday, possibly the cheapest piece of camera gear I've purchased in quite some time. However after 2+ hours on the phone with tech support last night, the damned thing still isn't activated. I'm hoping to have this fixed by today, as there's nothing worse than having a toy that can't be played with! First world problems, to be sure...Black Friday and Christmas is just around the corner.
Just sayin'
:ROTFL:
A pict taken with VC 15mm 3rd generation. Cropped 90% so effectively focal length is 13.5 mm. Some vignetting, but this lens (at least the sample I have) is tack sharp. Picture processed with Capture One.There are disadvantages to the ES, but as you and others have noted, they're pretty overblown. In my prelim testing with ES and the X1D, "normal" handheld shooting (i.e. point camera and shoot it) worked just fine.
So simple and so beatiful,A pict taken with VC 15mm 3rd generation. Cropped 90% so effectively focal length is 13.5 mm. Some vignetting, but this lens (at least the sample I have) is tack sharp. Picture processed with Capture One.
