Results 1 to 11 of 11
Thread: SUPER ANGULON XL 5,6/72mm FOR DIGITAL
    KEMPTEN / GERMANY
    1,513
    116
    I have a Schneider Super Angulon XL 5,6/72mm and have used it for LF 4x5 images , analog . I think , this is a great lens .
    Has anyone ever used that lens for digital and what are your experiences ? ?
    That question comes up for me , because I would like to use that lens with a CFV-39 digital back .
    Especially for stitching , because the image circle of that lens is 229mm .
    Would be ideal for a sensor size of 37x49mm .
    Jürgen
    Mar 2009
    72
    Re: SUPER ANGULON XL 5,6/72mm FOR DIGITAL
    Schneider SA 72XL is a great lens for both film and digital. I have used it with my Sinar 75LV digital back, and the images are amazingly sharp with wonderful tonality. Color fringing is well controlled if you use its sweet spot. However, as for stitching, I found lens cast could be a problem and was difficult to correct.
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by MFnLF View Post
    Thank you for your information .
    After contacting ARCA SWISS , I found that an adaption for digital use with my ARCA SWISS 4x5 is not possible as the required format reduction board is in the catalogue but was never produced .
    Jürgen
    Jul 2008
    Shodoshima, Japan
    258
    I assume the Arca has a Graflok back. So why not use a Graflok fixed or sliding adapter?
    Kumar
    Los Altos, CA
    10,486
    1031
    I am pretty Kapture group makes sliding backs that mount directly to Arca 171 or 141 rear standards...
    home: www.getdpi.com
    KEMPTEN / GERMANY
    1,513
    116
    Thanks Kamur
    I googled for graflok and their products , but that is not quite what I am after.
    Thank you for your hint to the kapturegroup products . I will carefully check .
    Yes , they have a sliding back or even a single back , what they call live video adapter , for many different view cameras .
    I do not understand "live video" properly . There is no live video MF camera .
    I think , they possibly mean live view .
    Any other idea ? ? ?
    Jürgen
    Jul 2008
    Shodoshima, Japan
    258
    Jurgen,
    Graflok or 'International' mounts are named after the Graphic/Graflex cameras. The mounts they used for mounting roll film backs are now standard on all 4x5 cameras, including Arca. Kapture Group makes adapters in Arca as well as Graflok mounts, and you can use either with your Arca. The Graflok mount is more versatile, since you can use it with almost any 4x5 camera.
    Kumar
    KEMPTEN / GERMANY
    1,513
    116
    Thanks Kamur
    Jürgen
    The above questions have kindly been answered by fotografz in an other forum .
    I will delay my decision , what I will do with my SUPER ANGULON XL 72mm
    lens .
    Too many open questions .
    Thanks to everybody who posted .
    Jürgen
    KEMPTEN / GERMANY
    1,513
    116
    I have met an expensive decision .
    I have sent my SUPER ANGULON XL 5,6/72mm to SCHNEIDER to get a focus mount adapted for use on an ALPA 12 SWA , optimized for analog and digital . I don't what other costs will come up .
    Jürgen
    KEMPTEN / GERMANY
    1,513
    116
    Here is a shot , I recently took with the ALPA 12 SWA and the SCHNEIDER SUPER ANGULON 5,6/72mm lens .
    Digital back was HASSELBLAD CFV-39 . Vertical shift =11mm , f=11 .
    No rework done in PHOCUS except LCC . PSCS USM = 100/1,3 . The second image is a 100% crop .
    Attachment 34916
    Regards . Jürgen .
    KEMPTEN / GERMANY
    1,513
    116
    Attachment 34917
    As the 5,6/72 Super Angulon is a LF lens , it is not really meant to be used for digital .
    But I think the result is rather good . Not crisp sharp , but it shows a warm softness . For the image sizes I mostly produce , this lens very well uasable .
    Regards . Jürgen .
