Mamyia ZD vs H3D with 22MP
Sr. Administrator
Staff member
IIRC -- and it's been a long time ago that I shot Contax -- you could only manually set shutter speeds to 8 sec or use B, but the way it was designed you got up to 30 seconds automatically in Av mode. Maybe somebody that owns one will confirm this.
carstenw
Yup, but given that the camera has both manual and electronic shutter release holes, you can use B to get times of any length. I don't know how that interacts with MFDBs though, not having tried that.
thomas
With a Phase back B mode doesn't work; so it's limited to the 8 seconds. Actually.
However you can use the DB like on a view camera - you just have to put a thin sheet of paper on the contacts of the DB so that there is no communication from camera to DB. You can use a flash sync and wakeup cable for long exposure in B mode. Works very well.
carstenw
Er, if the Contax can do exposures of any length with a cable release, the very worst case would be that it could not communicate this to the back, and so Phase could have provided a way to start the back manually? Or am I missing something?
carstenw
Well, one would imagine so, if it were really their favorite camera, but if it works with a piece of paper between the contacts, then all they would really need to do is to make a mode that behaves like that, no? Too weird.
