Don Libby
Can't be. It's too slow.....Isn't that Graham's suv?
:ROTFL:
:ROTFL:
Hi EdHello fellow Cube fans! Quick question... I remember seeing someone on here (Graham, was it you?) indicate a nifty idea that involved putting some RRS parts between the Cube and a tripod, allowing you easily to remove the Cube from the pod. Great for travel when it needs to be removed readily and also great if you want to swap the Cube between different tripods. I guess it also gives more confidence that the Cube is securely attached as it doesn't depend solely on a 'tight twist'. Trouble is, I can't find the explanation of the parts involved.
Can anyone here remind me? Thanks in advance!
Ed
