Results 1 to 6 of 6
Thread: IQ180 and Schneider 60mm XL
    Sep 2009
    1,587
    Hi all,
    I've tried searching the forum for this, but the results that come up lead me down a rabbit hole...
    In short, what's the story with the IQ180 and Schneider 60mm XL? I'm making tracks to jump on a great IQ180 deal (seeking funds tomorrow... Gulp...) and want to know how this combination handles in terms of colour casts, micro lens ripple etc with movments. How many mm could I expect to employ without running into problems, even with LCC shots?
    I ask because I know the 60 XL is not retrofocus like the Rodenstock wides, but at this focal length does it matter? I currently have a Rodenstock 55mm APO–Sironar Digital, which has been great with film, but I worry that it will clearly show its age on this sensor. Hense the thought of upgrading to the 60XL while (if) getting the back.
    Thanks for your help,
    TJV
    Sep 2011
    1,069
    83
    Re: IQ180 and Schneider 60mm XL
    If you're talking about the newer Schneider 60 XL 5.6, it is about as good as it gets. Very sharp, large IC, and you can use the CF if you like, but not necessary. I use it with an IQ180 on an Arca system.
    You can also see a great review done by CI here:
    https://captureintegration.com/lens-testing/
    Little Rock AR
    1,926
    3
    Quote Originally Posted by tjv View Post
    Hi all,
    TJV
    Hi, I have the 60XL in R mount and have used it a few times on the 180 (during a value add repair for my 260). I have the CF for mine as I feel it helps a bit on extreme shifts.
    I don't use rise/fall, but shift a lot.
    On the 180, I found that the color cast/loss of saturation seemed to be too extreme by 18mm, where as on a 60MP back I have taken this lens to 25mm of shift.
    It's nothing like using the 35XL on the 180, i.e. it's a much better combination and you should have good success with it.
    Congratulations on the new 180!
    Paul
    Paul Caldwell
    [email protected]
    www.photosofarkansas.com
    Sep 2011
    1,069
    83
    Agree with Paul on the limits. I frequently use +/- 15mm in landscape orientation with my Arca without any issues. Where I find the large IC useful is that I can shift 15mm and use rise/fall without problems.
    I can go up to 20mm if needed. Beyond this is trickier and very dependent on your standards and the subject matter.
    Little Rock AR
    1,926
    3
    I should add, the IC on the lens is 120mm as I recall. Schneider doesn't put the IC edge indicator in their glass, so you can easily use the full IC for a shot and as Jagsiva mentioned you can make excellent 9 part shots using rise and shift, center and shift and fall and shift, (you can also skip the center and just have 6 and rely on overlap). You will not see the massive black vignette that occurs and the even worse white bands (before the black) that pretty much ruin anything shifted past 15mm on a 40mm Rodie.
    I will say the 60XL is not that great wide open or close, I tend to try and stay at F11 to F16 even when shifting, which in low light on CCD back can be somewhat problematic.
    Paul
    Paul Caldwell
    [email protected]
    Sep 2009
    1,587
    Thanks all.
    Wish me luck...
