who can repair a Hasselblad 110/2 FE lens?
epforever
I have an FE 110mm f/2 whose aperture blades no longer close / stop down. Does anyone know who can work on this? I emailed with Hasselblad NJ, and they say Sweden can't work on it.
My first thought was David Odess. I emailed him.
thanks
ethan
jng
Yes, David Odess comes to mind. You might also try Bob Watkins at Precision Camera Works (https://www.precisioncameraworks.com). He recently moved to Northern California from the Chicago area. Not sure who's open during these shelter in place times but worth an inquiry.
Hope this helps.
John
epforever
Hope this helps.
John
Thanks -- I've worked with Bob before and will give him a try. FYI David Odess can't service the FE lenses.
Still taking more suggestions. Thank you.
e
jotloob
thanks
ethan
Ethan . I don't know where you live , so my hint might not be convenient for you .
But , you could try ULF KUEHN . He is a former HASSELBLAD technician , and still works in the house of HASSELBLAD in Germany . I got my 203FE and 201F plus 2 film E12 backs serviced by him last year . Try [email protected]
epforever
Jurgen -- thank you. I ended up receiving this same suggestion on photo.net. I emailed him, and he is working on either securing or fabricating the part.
best,
ethan
dorigatti
Another repairman you can try is Wico Jansen in The Netherlands (http://www.hasselblad-reparaties.nl) Tel +31 610708324.
He is an expert. Fixed my 30 mm CF by manufacturing an unavailable part from scratch. He also worked on my Hasselblads for yers and always produced top notch work at reasonable prices. However, not sure he works on F lenses. Worth an email in my opinion.
Carlo
epforever
Carlo
Great -- I've emailed him. Thank you.
ethan
jpmose
Hi Ethan,
Did you ever find a source for repairing "F" lenses? My 50mm f/2.8 Distagon has a frozen diaphragm. Thanks for your time!
JP
