Don Libby
Sandy and I arrived in Sedona this afternoon for a shoot we had planed and the second phase of the comparison between the WDS and WRS-1000.
One of the questions that was asked was if you could shoot either camera handheld and I've got a partial answer. The answer is partial as I've only shot handheld with the WDS this afternoon and I have proof. The answer is yes. I believe but have no proof as yet that you can shoot handheld with the WRS-1000 however I also feel that in this case size does or will matter and it'll be easier with the WDS.
Sandy took this while I was taking
this ...
I decided to do a 3-shot 2 row (6 images total) pano showing the individual rows then the finished image.
Top row:
Bottom row:
Finished image:
I had meant to do the same with the WRS-1000 however I screwed up and only shot one row of 3.
I'll reshoot tomorrow showing the separate rows then finial image with the WRS-1000.
Something I've noticed that really shouldn't be of any surprise to anyone is the image quality coming from these two bodies. But then again it really isn't the body rather the excellent lens and digital back; the only thing that changes between the images is the camera body. My opinion is that with the proper lens and digital back it won't matter which body you decide on as either way you'll get great images. The deciding factor is workflow. I still don't like the fact I have to move in front of the camera to change movements as that simply doesn't fit my workflow and for that it's a deal breaker. The other area I'm totally against is no real easy method of switching the orientation of the back; Cambo really did it right with the WRS-1000.
Just a note here: I've modified the way I address the 1000, in the past I used RS-1000 while after looking at the Cambo site I should have been using WRS-1000.
While I'm making notes: The panorama images are "as is" directly from CS4 with no other post processing and no cropping, the white area around the boarder is what CS4 shows upon completion of stitching. I did cheat a little and shot a custom white balance before shooting the images.
More to come.
Don
It'd be nice to try Guy's new P40 on either camera!
this ...
Top row:
Bottom row:
Finished image:
More to come.
Don
