Guy Mancuso
Administrator, Instructor
Looking for some Zeiss 25mm F2 images I shot in the past to post
Thank you Sir!40mm Ultron test images and snapshots. Best advice hit download go to breakfast and enjoy the morning. LOL
Its big
https://www.hightail.com/dl?phi_act...018636&email=61a3e3f62bc216799b284351c0941895
Where is this slider Guy? Or is it the sharpness slider that works for the corners on a profiled lens?As you can see the very extreme corners are a little soft. This is expected in these super wides and i have yet to see a lens not do this except for a tech lens. But there is a silver lining. In C1 there is a slider for corner sharpness and in the second image I made that correction and it cleans up very nicely.
It's under lens correction tab in C1Where is this slider Guy? Or is it the sharpness slider that works for the corners on a profiled lens?
And just because I'm so happy to share, I've found my holy grail in the non tech cam wide angle lens: the Leica Super Elmar S-24mm. Incredible borders and corners sharpness. As a former IQ180 + Rodenstock 32mm HR user I'm simply blown by the quality of this S-24mm ! Liked the S system, love it nowI also while I was testing did the Zeiss 25mm F2 lens corner test which looks very good. But as you know this focal length is tough in the corners so the 25mm as damn good as it is has in the extreme corners a little softness and frankly so does my Leica 19mm R lens. I do not know a lens outside a tech lens that does not. So do keep that in mind
Hey that's cheating that's MF. LolThank you Guy for those tests, very informative.
Sorry if I'm being obtuse Guy but I only see a sharpness slider there and on a non profiled lens it seems to sharpen throughout the frame. That said I wasn't trying it on your picture, does C1 have profiles for the zeiss lenses? I'm in work now so can't check but I'll have a look at your files in C1 when I get home.It's under lens correction tab in C1
