There's no full info yet in any case - Lloyd tends to put up headline stuff when he notices it as a heads up that he intends to investigate further, but it struck me from what he writes that it sounds very similar to what you're seeing and I think that pitch/yaw hypothesis might have something in it. I'll let you know if any more stuff comes up.Interesting, Tim, but for full info I'd have to subscribe, a big no no for me.
With IBIS tuned off, and camera located on a sturdy tripod, manual focus- i.e. treating A7RII and 16-35mm combo in a similar way as I would use MF digital - then the issue seems to go away. Then its just a very good camera lens combo that renders MF redundant :thumbup:
I guess as Lloyd suggests, there must be a downside to the sensor moving to correct pitch and yaw, meaning the sensor may not be parallel to the plane of focus. That would not be a fault, simply an downside to IBIS.
Put the camera in manual mode and you will get a visual meter of where infinity stop is.Actually it could be FC with a varied focal point. You see this all the time with WA on the Sony, if the focus is dead center the edge will show soft or "smeared", but if you focus just a tad before infinity the DOF at f/8 will bring in the edges.
It's why I hate AF on the Sony cameras with a passion, and the lack of a hard infinity stop is.....grrrrrr. :banghead:
I had this happen on the nex-5n and that nice little 10-18 all the time.
That's a good tip, I did not know that Is that true on all A7 models?Put the camera in manual mode and you will get a visual meter of where infinity stop is.
Yes. I only have the original A7 and A7R as of now. This is specifically for native FE lenses with focus by wire. In short when you turn the focus ring a digital meter will appear in the EVF (or rear LCD I believe as well) showing "where" you are in the focus range.That's a good tip, I did not know that Is that true on all A7 models?
Its a bit rough and ready. I have also noticed when using MF that you can focus quite a long way beyond infinity ("to infinity and beyond!").Put the camera in manual mode and you will get a visual meter of where infinity stop is.
Minority opinion: I'm glad they're not! The main advantage is that remain as small and light as possible IMHO.Its a bit rough and ready. I have also noticed when using MF that you can focus quite a long way beyond infinity ("to infinity and beyond!").
Better than nothing, but not great.
Its a pity all Sony lenses are not like their excellent 90mm macro G OSS, which has the best of both worlds - full autofocus, and a clutch that allows you easily to switch to good old fashioned manual focus, with a distance scale engraved on the lens barrel. That's so much better than the electronic approximation of distance on the screen in MF mode.
