glenerrolrd
JackRoger:
It doesn't, and that's why I did the local Contrast and Brightness adjustments in CS. HOWEVER, the color editor allows you to very accurately select a specific range of H, S and L values. Once selected, I can then adjust the H, S OR L, OR any combination of H, S and L, to another unique range of HSL values. So it is a localized adjustment as it relates to COLOR selected, as opposed to AREA selected.
I think this was posted before but in either LR or Bridge you can selectively adjust any color with H/S/L and you have an eye dropper that allows you to pick the spot and increase or decrease H/S/L and it will mix the colors . I think you do this in C1 by using the color wheel.
They don t have the ability to adjust H/S/L through a LAA..which I assume you could do in CS4 with layers .
I do learn a lot from seeing an example thanks for posting this one.
