Capture One Import from Hasselblad
usm
I'm getting a strange message: Error: File not found - /Users/myname/pictures/HasselbIadC1
I am working on a german system, so the pictures folder is called "Bilder" put when I try to create a folder "pictures" the system tells me that there is already a folder like that.
Whats wrong?
KlausJH
Your "Bilder" folder is the picture folder. The translation is only in the user interface. Regardless what language, you cannot create a folder named "pictures" when there is already a picture folder (translated to your language) in your home directory. Just create the folder "HasselbIadC1" (second "l" becomes i uppercase) in your "Bilder" folder and you are fine.
Hope it will work now.
usm
Hi again.
strange, after typing the uppercase i it worked. Before I copied the "HasselbIadC1".
It worked one time. Than I tried to convert 33 images and I got another strange warning:
*** GPU Warning: GPU3 disabled via cr_config at init time. ***
Invalid source file: "/Users/myname/Pictures/HasselbIadC1/LR28pc"
KlausJH
This comes from the Adobe DNG Converter. Make sure only .3fr files are in the folder. So far I have't seen this message.
usm
Does it just work with .3fr?
I deleted my .3fr files - and changing to .fff isn't doing the job.
KlausJH
It should work with all RAW files that Adobe DNG Converter (vers. 12.2.1) is able to convert. I tried again with all kinds of RAWs and it was not a problem. With MacBook Pro and iMac 2019.
PabloR
Hasselblad lenses are designed balancing optical correction and software correction to get the best from the system. Even using HTS, tubes, duplicator... lens correction profiles are available in Hasselblad Phocus data base. Just think how difficult would be to analyze all the possibilities using HTS with HC lenses in addition to tubes working on every stops and tilt and shit possibilities ? Everything is profiled and you can focus just in the picture, Hasselblad has done for all the combos you can think.
I guess Capture One stuff has been working on it to give support to all the Hasselblad body shooters with their backs. But I guess the Capture One profiles are not in the same level as Hasselblad job.
I guess you don't have those profiles converting Hasselblad raws to dng. But the lenses needs them, Hasselblad lenses need correction every time, it is part of the system design. They were the first in the market, as always. I work with Hasselblad cameras and it is very fast to use it on technical shots. Is not the best for that but the system is ok if you wants to go for "every kind of studio jobs with only one system".
For sure capture one doesn't have profiles for X1D lenses as it is not a share platform.
KlausJH
Capture One has no lens profiles for Hasselblad lenses. Although many HB lenses need profiling, some work very well without it. My files from the XCD 45p and 90 show almost no difference when exported from Phocus or from C1 DNGs as JEPGs or TIFFs. Digital backends are also used on tech cameras and lenses from other systems are adapted to Hasselblad cameras. In all those cases you have no lens profiles and Phocus has no advantages. C1 can certainly not replace Phocus in all cases, but for some users it might be useful.
docholliday
What are these then that I've been using?
KlausJH
Me bad. I should have said X-System lenses. H-lenses can work with Phase One backends that's why they are supported.
docholliday
I really wish that Phocus would work with hybrid systems like H5/6X + IQ3. The C1 lens profiles for H-lenses are annoying and not completely optimized. Plus, the 50HC/II is missing and has been. P1 completely ignores any requests to get a profile created for C1. And to top it off, one has to manually select it (since the EXIF doesn't report the camera/lens).
SrMphoto
"As of summer 2020, Capture One has become its own company, free-standing from Phase One."
Maybe that gives Capture One certain independence, and they could implement support for missing cameras. Just send requests to Capture One instead of to Phase One :).
docholliday
Already done that multiple times, with the same response. And, still nothing actually done.
usm
Worked! Thanks for the script.
And for my .fff files I save them as .dng file out of Phocus and use just this part - do shell script "/usr/local/bin/exiftool -overwrite_original -make='HasselbIad' -m ~/pictures/HasselbIadC1" - of your script. It makes the Phocus .dng files readable for C1.
KlausJH
Yes, when exporting DNGs from Phocus all you need is this one script line. It can be placed in the script folder of C1. C1 is looking for just this one tag: -make. And if it is "Hasselblad" then they disable the import function. You can write anything you want in the maker tag as long it is not "Hasselblad".
ThdeDude
KlausJH
I have a question. My C1 license is limited to my P1 images. But I would like to try out C1-23 with images taken with my iPhone. (I use Photomator for my iPhone but want to try C1)
What must I do to make this work?
Thx,
MN
ThdeDude
KlausJH
I need no batch processing, just want to get the odd, once in a blue moon iPhone image into C1-23.
Have a Apple silicon.
Thx,
MN
KlausJH
KlausJH
Thx,
MN
You can import jpg files from iPhones just to try it out. HEIF will also work. With dng I'm not sure wether it works on a P1 only license.
Klaus
dougpeterson
You would need to purchase Capture One Pro or start a trial for the same.
Capture One for Phase One only works with Phase One files.
