Hi,So not only CCD sensors, but also most recent CMOS sensors are made of four tiles?
schneider 35 xl on 50 and 100 MP sensors from Sony dont work at larger movements, even 10 mm is too much.This is 20 mm shift image. I will check the 10 mm and 0 mm tomorrow.
A 2014 test review published by Digitaltransitions, they had similar kind of results with IQ250 orientation affecting to colour cast:What I found out meanwhile:
There is no sensor tiling when using the back turned to the right side (CCW270) even up to 20mm shift.
When turned to the left side (CCW90) I can see the sensor tiling above 15mm shift.
Same when the back is in landscape orientation (CWW0), sensor tiling visible at 20mm.
Regarding the sensor tiling: Movements until 15mm are ok. When rotated CCW270 I think 20mm are ok.
But there are other problems. I think it is the Phocus Software and not the Sensor.
There are, lets say "artefacts" when processing the files in Phocus. When using Capture One the artefacts are gone!
I converted the FFF fees via Phocus to DNG files and changed the exit data with a script to "Hassiblad".
Rise 20mm, rotated CCW270, middle and middle/top.
Left: processed in Capture One
Right: processed in Phocus
There are horizontal blue and vertical yellow stripes (view at 100%) in the Phocus version. Nothing in the C1 version.
View attachment 184882View attachment 184883
These stripes or artefacts are also very strong on the left and right side of the center. Like on the files:
Rise 15mm, rotated CCW270, left and right
Left: from C1
Right: from Phocus
View attachment 184885View attachment 184886
When rotating the back to CCW90 they are even stronger and more yellow instead of blue:
The same file from C1:
My question is: Are these stripes maybe from a not centered lens?
Or is doing Capture One just a better LCC job?
The problem with C1 and Hasselblad files is the lost of the better color from Phocus.
I can provide FFF files if interested?
All images are made with the electronic shutter.
Greetings.
I think you are correct according to my experiences with CMOS backs and the ALPA SK 28 and 35 lenses. Even though I do not require their use a lot, when I do shoot with them, I never shift and always use their center filters. The files clean up well in Phocus.FWIW, I never had a great experience on the CFV II 50C and the SK 35XL. Shift was really limited to <10mm and even that would required LCC frames. I moved to the Rode 40HR and was much happier in that regard. I think any of the 50MP 33x44 sensors will basically have the same challenges with a lot of those earlier SK lenses.
not really, 35 HR has distortion- as all retrofocus wide angle lenses has, also the big brother 32 HR.There is no good or bad 35mm solution for the 33x44 sensor. The Rodenstock HR 35 has a lot of distortion and the SK 35xl has a lot of color shift. Both are more or less shift able until 15mm. I prefer to deal with the color shift witch is easy correctable with LCC.
The 40mm Rodenstock is to long for me.
There are rumors of a Hasselblad shift lens for the x system in the 28/35mm range. But maybe it is just what I am dreaming of.
