Close-ups shot on Leica cameras
Bill Caulfeild-Browne
Today, just out of curiosity, I tested to see if I could get a 1:1 image from the Macro-Elmar M. The answer is...almost!
I mounted the fully extended lens on a 40mm Novoflex extension ring set and it in turn on the fully extended Macro-Adapter M. As can be seen, the resulting image is about 38mm. I assume the sensor is 36mm long. In practical terms it is 1:1 image. (Note the ruler was not precisely square to the camera so there is some fall off to the left.)
Chris C
..... to see if I could get a 1:1 image from the Macro-Elmar M..
I mounted the fully extended lens on a 40mm Novoflex extension ring set and it in turn on the fully extended Macro-Adapter..... resulting image is about 38mm..... In practical terms it is 1:1 image.
Bill,
Thank you for sharing this practical information, you used the 90mm Macro-Elmar [?]. Would this be a candidate for good cam-scanning 35 mm film, or do you think the lens is slightly out of it's comfort range?
.............. Chris
