Alkibiades
Now I found a little bit time to make this comparison possible:
Comparision between 3 lenses that are a short wide angle with very naturalistic look ( wide normal lens), that is Digaron-W 50 mm, Apo Sironar Digital/Sinaron Digital 55 mm and Apo Digitar XL 60 mm.
They will very offen used for naturalistic looking architecture shots and landscapes, as also for stiching landscapes.
The oldest and cheapest here is the very known Rodenstock Apo Sironar Digital ( here Sinar selected version Sinaron Digital) 4,5/55 mm.
This is the latest Version with the pink ring. The earlier Version has a green ring. The lens is physicly a Apo Grandagon 55 mm that was improved for digital photography. Indeed when you use aperture 22 you can even shot 4x5 inch.
Anyway the usefull aperture for this lens used digital is 8-16. Even when this lens is the oldest here The lens is still known for very good sharpness and have no problems with the color cast that make so much symetrical wide angle lenses unusable with some backs. The lens has symetrical 8 elements design.
The second is Schneider last generation lens that is probably the sharpest lens that schneider made. The lens has symetrical 8 elements lens design.The lens came together with 43 xl and latest 120 aspheric.
All of this last generation lenses are superb.
The third is the latest Rodenstock lens: Digaron-W 4/50 mm that is a very complicated retrofocus lens design, the brother of 4/32 and 4/40 mm Digaron-W.
this is also the most expensiv lens here and will also be offered in the new Phase one XF shutters for nice prices. The Digaron has smaller image circle: 90 mm but still allows 20 mm on sensor 33x44 mm.
The test is made with Linhof techno, for all lenses, the back is Phase one 250, with sony 50 MP sensor. The results will be the some with all same sony sensors, build in Hasselblad, Pentax or Fuji cameras. Also the 100 MP sony sensor has the same pixels destiny- you could say the 50 MP back is cutted 100MP back.
