Do you mean through post image processing?Could it be a sharpening artefact?
All I do is rotate, crop, and size for posting online. I don't use any sharpening tools.
I wonder whether the halos are due to over-sharpening during the scan itself - was sharpening enabled on the scanner? If so, you might try switching it off although cleaning the plate seems like a good idea regardless.Just pulled the negs to have a look-see. On the light table under a 15X loop, no halos are seen, Suggesting the problem is likely with the scanner. I have noticed a light fog building up under the glass of my Epson V750. A common problem with these scanners as the plastics gas-off, that demands an annual cleaning.
I'll do some scanner maintenance and re-scan. Give me a couple of days to report back.
John
Do you see the same halos in the large file before downsizing?I don't use any sharpening options during scanning, but I do perform multiple exposures.
Thanks, that could indeed make sense, I have a V700 also with a slightly fogged glass that I've intended to clean for some time but so far have been unsuccessful. I found this exploded view of the scanner: V700/V750 diagrams. Do you have any tips how to remove the plastic caps (part # 165) so you can reach the screw to take the cover off and be able to clean the underside of the glass (where the fogging sits)? I've been trying different methods but can't get them out.Just pulled the negs to have a look-see. On the light table under a 15X loop, no halos are seen, Suggesting the problem is likely with the scanner. I have noticed a light fog building up under the glass of my Epson V750. A common problem with these scanners as the plastics gas-off, that demands an annual cleaning.
Mods, if you want to move this discussion elsewhere since it's more about scanning hardware than MF film images feel free to do so, but pls. leave a little note where you moved it to if you do.
Oh, yeah, Darr that is a wonderful image!!!![]()
Mamiya 6 + 50/4 + Rodinal
[ long exposure ]
Cliche or not, great capture. I think the car makes the shot. I would have paid the owner to sit behind the wheel with the window rolled down, arm hanging out and smoking a cigarette. But that's just meA bit of a cliched location, but I had decided to shoot film for the first time in 15 years, and it was raining, which is rare in Southern California, so ran out to Mojave to shoot this shot. I tried waiting for the cars to clear frame, but they just kept coming one after another. In my former profession, Location Manager for TV Commercials, I would have just paid the guy off and got him to move his car, but that was then and this was now.
Mamiya 7ii, Portra 400, 80mm, Nikon Coolscan 9000, and Negative Lab Pro.
I like your idea much better!Cliche or not, great capture. I think the car makes the shot. I would have paid the owner to sit behind the wheel with the window rolled down, arm hanging out and smoking a cigarette. But that's just me![]()
I have a Mamiya 6 kit as well and can attest to the beautiful rendering and sharpness of the 150mm lens. It is the unsung hero of the Mamiya 6 kit.![]()
Mamiya 6 + G 150/4.5 + Rodinal
[ scene from my local library ]
