Yes, my fingers gave out before the X1D. I really need to come up with a better set of gloves for shooting in frigid temps.Looks darn chilly, Howard!
I have not noticed the EVF shimmering effect you describe. The EVF on my X1D seems quite similar to my Sony A7RII. As for the color balance of the EVF, if you change the WB for the camera, it also changes the color balance in the EVF. If the color balance in the EVF is quite blue, try AWB or the Shade setting for WB. Perhaps you already tried that.Some X!D images from a photo workshop in New Orleans this past weekend. The camera behaved fairly well. I had a few system errors that required me to pull the battery, but that was it. EVF shimmer is still annoying. EVF image is way to blue. But I'm now used to the EVF Blackout/shutter lag. I have the timing down now. I move after the exposure, but before the EVF goes live again.
Nice report. Thanks. On the color balance of LV in the EVF, if you change the WB for the camera, it also changes the color balance in the EVF. Perhaps you already tried that.Just got mine this evening and did some fooling around in the dark.
I mostly shoot flat field macro abstracts on a tripod in the field, so small and good at focusing are what I care about. I like to print very large (2-3m on the long axis sometimes), so I end up stitching and/or stacking a lot. AF is useless for my work, and I like Zeiss and Leica manual helicoids for precision and just because they make it more fun. I also need to assess focus in all four corners of the frame, and that's maddeningly slow on my d800e's.
I'm happy to report that the "focus management" experience is pretty good on this camera.
The fly-by-wire mechanism is well modulated, although the very finest focus increments on the 90mm are a tiny bit less precise at minimum focusing distance than I'd prefer. I suspect a future macro lens will better this.
The live view latency is very good: so much better than on Nikon. I can't feel any delay, and the critical double-tap to zoom in and out is also instantaneous both ways. That means I can check all four corners in maybe 10 seconds instead of 40, yay!
When reviewing an existing image immediately, there is a delay at 100% view while waiting for the file to finish writing (I guess). I'm not sure why we need to wait for that, so it's possible that instead it's a rendering delay. Anyway, there are several seconds of wait time for a 100% view to render. The good news is that zooming around to check the corners, after that, is instantaneous.
I set up the iPhone Phocus app and gave it a go. It's a bit buggy and kludgy, but they did get it working in time for shipping. The good news is that the wifi live view is also pretty good: very low latency on focus, and a bit of delay when zooming. Remote focusing is then possible in very precise steps, although the UX seems rough to me. Nevertheless, it's a whole lot better than doing a handstand to focus on the rear screen when the camera is down low! I'd really prefer an articulated screen, but at least we knew that before ordering.
Nit-picky areas for improvement:
1. I'd like the EVF MF experience to be more flexible. In MF mode, it auto-zooms for focus assist, but only to the pre-selected AF point. I would like to be able to move the zoomed view around with the wheels (or touchscreen) while focusing to verify in EVF quickly. Sometimes it's too bright to use the rear display.
1b. Related to that, I'd like to be able to MF through the EVF without it zooming, as an option.
2. I'm confused about the shutter management features. There doesn't seem to be an EFCS (nor an ES) option, but there is this Mq mode that supposedly lowers latency. I don't care about latency, but does it improve the vibration mechanics? And what's the point of having it on the mode wheel? Maybe just a button would be easier.
2b. In the iOS Phocus app, there's a button for mirror lockup. It appears to be doing something when I press it. What's it doing, and is that improving things? And, if so, why isn't that button on the camera somewhere?
3. The "manual AF" button (AF-D) is a little too far away for my thumb. I like the deeper grip, and I don't really use AF much so it's not a big issue for me, but I think some people will find it uncomfortable compared to other bodies.
4. I'd like a vibration-delay release like the XF. Barring that, the option to set delayed release to 1 second would be nice (the current minimum is 2).
5. With their precision control, auto focus-stacking would be pretty easy to add...
6. They definitely intended the dual-SD-slot setup to allow for duplicate writes rather than just overflow. Maybe they'll squeeze some more performance out of their hardware and add this feature for us one day.
7. Like others, I'm not enamored with the color management on either display. I'm sure the gamut is just not very good, but it'd be nice to have a way to tweak the WB a little or something.
8. In-camera battery charging via USB-C PD.
9. Battery readout in percentage.
And here are the dream requests for X2D:
A. Four-corners live view for focus. A few cameras now have split-screen focus, although the setup of it looks awkward... but we know it's possible on Sony CMOS already. In my dream world, I could hit a button and see all four corners plus the center, all live, at the same time. How awesome would that be?
B. Multishot... c'mon Hasselblad!
In summary, my guess is that the GFX will be the better camera for most of what I do, but I do like this one. I'm inclined to keep it for now and wait and see if there are any show-stopper issues lurking in the Fuji workflow.
Hi. I actually shut off EVF preview. I didn't think it accomplished much for me. I trust the histogram more than the EVF preview. Plus if you are using flash and your camera settings are below ambient light, the EVF goes black as soon as you focus, so you can't see what you are shooting. Just a nit. I worked around it. We were out in a swamp in the bayou near NOLA. The EVF was very blue with EVF preview off. Even with auto WB on, the LCD and EVF colors aren't stellar. This is all nitpicking. I love the camera, but there are a few bugs yet to be worked out. Not really any different than the intro process on the H5 and H6's. Hasselblad gives us a functional camera and then improves things over time.I have not noticed the EVF shimmering effect you describe. The EVF on my X1D seems quite similar to my Sony A7RII. As for the color balance of the EVF, if you change the WB for the camera, it also changes the color balance in the EVF. If the color balance in the EVF is quite blue, try AWB or the Shade setting for WB. Perhaps you already tried that.
Unfortunately, there is no real time histogram in Live View. To judge exposure, it's either the EVF simulation or the Light Meter in the EVF during Live View.Hi. I actually shut off EVF preview. I didn't think it accomplished much for me. I trust the histogram more than the EVF preview. Plus if you are using flash and your camera settings are below ambient light, the EVF goes black as soon as you focus, so you can't see what you are shooting. Just a nit. I worked around it. We were out in a swamp in the bayou near NOLA. The EVF was very blue with EVF preview off. Even with auto WB on, the LCD and EVF colors aren't stellar. This is all nitpicking. I love the camera, but there are a few bugs yet to be worked out. Not really any different than the intro process on the H5 and H6's. Hasselblad gives us a functional camera and then improves things over time.
Beautiful shot!!Home of the brave
Joe
Please drop an email to Hasselblad requesting integrated step focusing it's been on the request list and the more people that ask the faster they might complete the firmware update including it.
Send email to Hasselblad
Can you please describe what integrated step focusing is? If I am going to request it, Ove may ask me just what it is that I want.
Hi Eleanor,A couple more from today using my 90 lens at iso 100. Antiques...a Music cabinet and old Grandfather clock. I keep hoping more people will post images, realizing it takes having the hard to get X1D but hoping more folks will get there cameras soon.Eleanor
PS I'm finding this camera has a wonderfully high dynamic range. I am using LR for all RAW processing at the present but using the fff files, not the 3fR.
