Yep, it is usually 1.5X-2.5X the cost of the actual print when above 8' feet in any direction. I think some innovation is needed in that regard so I am working on some new free form display concepts with a designer at the moment for my home need.
And real good to know on your size options, thanks! At large scale, what is the highest dpi you would be able to put out?
Your welcome, AI_Print! It was actually a bit more than that for a few of these, just because some things had to be handmade. For the really big'uns, we machined an adjustable stretcher bar system made from custom cast aircraft aluminum. (used my contacts in LA movie industry to source that)...The problem seemed to be that as the print dried, outgassed, settled, warmed and cooled, the bars needed to be adjusted. One client wanted us to try plywood? LOL fuggettaboutit! Aluminum because if we did it out of traditional materials it would have weighed a ton (literally, if one of the giclée's used wood, we calc'd it to weigh over 2000LBs due to the steel reinforcement to keep it from warping too much)
Highest DPI our BAP (Big *** Printer) can do is about 1440 I assume that is your question?
DPI (dots per inch printer resolution) refers to printer resolution, the printer we use makes a drop size roughly 720-1440 DPI which we tested (ad nauseum) to be overkill for what any canvas can practically hold.
If you are referring to PPI (pixels per inch digital image resolution) we can handle whatever you got, but there are diminishing returns above 180PPI at size due to HiFi frequency modulated screening technique that all these printers use.
best,
e
