… or even price reduction which usually happen after some time.
Pretty sure, they have done this always with the SL models!You are sure?
Jochen
I'm not sure if this has been addressed elsewhere, but it appears the "remote" (cable?) release rca jack is not present on the SL3 per the manual. There is a USB-C type port on the side (pg. 28, #38) that is labeled "remote release" in the manual, but there is no further mention of remote release, other than via Focus, anywhere else in the camera.
Anyone else know anything differently? If true, is there another Leica camera that has a cable release for this type port?
It also appears that B mode is used by pressing the shutter on then again to close the shutter (introducing camera shake) and T mode is limited by the pre-programed shutter speed lengths the shutter can be open...
Actually spoke with Josh at Leica Miami and he said the SL2 and SL2-S Leica remote release will work with the SL3.I’m guessing that they expect folks to just use the Leica Fotos app.
You can put your hand in front of the lens before closing the shutter if you're worried.I'm not sure if this has been addressed elsewhere, but it appears the "remote" (cable?) release rca jack is not present on the SL3 per the manual. There is a USB-C type port on the side (pg. 28, #38) that is labeled "remote release" in the manual, but there is no further mention of remote release, other than via Focus, anywhere else in the camera.
