On a rigid copy stand the electronic rolling shutter of the back should suffice for constant LED illumination. Flash has more fluctuations in terms of light output and color temperature than LED. But I’ve also seen film digitization setups with flash illumination. In some environments where vibrations can hardly be eliminated flash can solve that issue.I actually tested the 105 vs. the 138 at Alpa's HQ for that purpose with a Kaiser RSD stand (I know, not ideal); the 105 was markedly better at the magnification of 1 and above which could be useful for stitching high-res scans of film or say 35mm. I therefore opted to get the 105 with the Novoflex bellows. I think the best solution would be 105 with a shutter, but this is only possible with an Alpa FPS which is out of production ...
If you’re using NLP, why would you need to import into C1? Or are you talking about the import during tethered capture?One learning from that exercise was that although super fast, the workflow with a repro stand still is a lot more "finicky" IMHO compared to a high end flatbed such as the eversmart or IQSmart III which can batch scan ... you need to import all into C1, then neutralize it there, export to LR and then tweak each with NLP ... still a lot better than drum scanning (just in terms of workflow), though, as you surely know
One issue I see with such a long focal length for art reproductions on a vertical copy stand could be limited height of the column to fit larger originals into the frame. I presume that was a criterion when Phase One decided to keep the normal focal length for the 72mm Mk II float reprographic iXH lens. If you have a tall enough copy stand and ceiling height to accommodate it, or if the object size constraints aren’t of any concern to you then based on the MTF data the HR 138 should be an stellar performer on a reprographic setup.I imagine if you go digitize books or paintings it will be great, don't you think? With flash to even out exposure at 5600 kelvin to get neutral colours ...
This is the problem I ran into when digitizing 8x10 with the 105 - it just takes a lot of time to really get everything perfect - ie it is "finicky". If one is happy with one-shot, eg for medium format negatives, the medium format back approach is very good - but as soon as stitching comes into play and you have this whole XY table thing and need to ensure planarity with laser, etc. it just takes time and can be annoying vs. fully automated high end flatbed or drum scan as you do it.But the level of automation allows me to use that time to work on processing or retouching previous scans. With the HXY scanner I can stitch to the same or larger size. But in my experience high quality stitching of very large files is labor-intensive. Extensive quality control is required to ensure that the necessary precision is maintained during capture as well as time-consuming manual adjustments for optimizing the stitch in the stitching software. While it’s still a bit quicker to get the stitched scan into Photoshop, the hands-on manual operation allocates the operator to a far greater extent than with a drum scanner. That’s one use case where I find my drum scanner more efficient.
-Dominique
Steve, have they been able to get the wiring to go through the lens body for the XT version of the lens, ie, will there be a difference between this version from P1 and the one sold direct via Cambo / Arca / Alpa?138mm lenses in Aperture Mount are already in the $15k - $16k range from Arca/Alpa/Cambo. So adding an X Shutter is going to push that into the $17k -$18k range, I expect.
Steve Hendrix/CI
There's a latch you can open in these shutters on the bottom side of the assembly - the side perpendicular to the Phase One lettering. You can see the square door faintly on the picture you posted. I have a few lenses here - you can open them up to use them on a Cambo wide body.From this photo I cannot see where the cable would attach. The location where it would normally be is not showing a connection port.
Theoretically, wouldn't it be possible to have:There's a latch you can open in these shutters on the bottom side of the assembly - the side perpendicular to the Phase One lettering. You can see the square door faintly on the picture you posted. I have a few lenses here - you can open them up to use them on a Cambo wide body.
The point is not about the 40 HR. It looks to me that the 138 HR for the XT will have to use a cable given the complexity of the inner lens assembly in which case the XT version wouldn't be so differentiated anymore and not really an XT version in the real sense, but just the Cambo version with X-shutter. And of course Phase wouldn't underscore that in the marketing materials by showing a dangling cable. And on the Alpa version you can use two 17mm spacers with tilt to create a 138 tilt and shift lens with X-shutter. But I am not sure - maybe Steve knows.
I am asking because as per the announcement the 138 HR is not sold directly, but by Cambo, meaning there's no real XT version of it. I suppose that would also mean no recording of shift information.
I think this is a quite crucial distinction, because it would effectively mean that due to practical constraints Phase One has chosen to not create a fully integrated 138 HR - which is a bit the whole point of paying the XT premium (ie cablelessness and shift info recording). I guess it has to do with the simple fact that the market for this lens is small and they are just taking Rodenstock's re-design to accommodate the X-shutter and for commercial reasons have chosen to just let Cambo sell a cambo mount version (which ofc fits on the XT like any other lens) - ie no real XT lens here ... we are talking about a great almost 20k short tele still ...Does probably not make much sense to invest in an XT mount customization with integrated electronics for shift recording given this lens is constructed in a more complex way and will sell in limited numbers given price
Yes, I guess, this is basically my question a) do we need a cable and b) does it record shift ...Theoretically, wouldn't it be possible to have:
- A 138mm Phase One lens with X-Shutter connected to the XT via a cable telling the IQ4 it's a Phase One lens, not a Cambo lens;
- The IQ4 recognising it's a Phase One lens and therefore reading the shift movements from the camera (the IQ4 IS connected to the camera anyway electronically)?
Sounds like it's doable, if Phase is willing.
Best regards,
Vieri
Or is this the only XT lens requiring a cable like all the others given complexity of the build?
Best
Paul
Thanks for clarifying - I think initially the intent was to have it "XT native", but the re-design was done by Rodenstock just now and there's probably not enough RoE to now take that design and further develop a special mount with electrical communication channels to control the aperture at the top ... It is an insanely precise lens, when holding it was evident that it has very high tolerances and is built in a more complex manner than the other lenses so really nice that we have a shutter based option at least ...Paul, as far as I know, this lens will not be sold by Phase One as a "native" XT lens, only through the Cambo/Alpa/Arca channels (of which we participate with all three).
Meaning that it will always require the communication cable, and as such, my instincts tell me that it will functionally operate just like other cable-required X Shutter lenses (no embedded shift metadata).
Steve Hendrix/CI
Maybe dependent on P1, but then they'd break their artificial differentiating factor for the XT lens premium in part as then the next question would why doesn't the back record shift metadata with all Cambo lenses equipped with a shutter on the XT body ... If they'd allow a non-native XT lens to record metadata the natural next question would be to let the XT do this for all "non-native" x shutter lenses it has mounted incl. some special stuff like Photo Greiner X-shutter mounted Schneider Kreuznach lenses with Cambo mount ... then the XT benefit would be reduced to the cablelessness.I’m surprised that shift information is not recorded. After all, that information comes from the camera.
They are the contract manufacturer for Phase One. They produce the XT and mount also the native XT lenses. So they won't ever act against P1's interests because they are legally prohibited from doing so and because it is the hand that feeds them and because they are co-dependent.I don’t have an XT. I presume an XT lens also provides focal length metadata?
So thinking aloud, can one (Cambo) make a smart mount that allows the XT to ‘identify’ the lens? Similar to the adapter you can can get to mount contax lenses on canon eos cameras.
Sorry, guess I’m rambling on and going off-topic now.
