Medium Format Ultralight Hiking Kit
MartinN
I have tried imaging the sun and sunspots with inadequate mount (tripod) and the pictures could have been ok, but the magnification was so great that any focusing action blurred the live-view and subsequently finding optimal focus was too difficult. Lesson learned, lightweight is equal to not enough stable for my purpose.
ggibson
In this case, there seems to be another issue than the cube diameter that is the weakest point. The tube diameter of the trekking poles is larger than the tripod legs. It seems the variables are in the wall thickness and, more importantly, the way the pole is fixed to the basicpod. It's just already wobbly without any camera attached. The trekking poles are really nice as trekking poles, and possibly usable as monopod, but certainly not suitable as tripod legs.
Edit: here are a few pictures.
Trekking pole head with protective cover:
Protective cover removed - note the plastic wheel and plastic construction. You do not have any means to tighten this really well beyond trying to screw the plastic wheel as tight as you can:
The two trekking poles connected to the basicpod, using two adapter screws that I bought (the 1/4" screw of the trekking poles is too short to mate with the thread):
Novoflex 5-section traveler leg vs trekking pole with adapter attached:
Tripod without camera:
Tripod with GFX attached:
The basicpod compared to two other hiking tripods I use, Gitzo G1057 and Feisol CT-3332. Here it's fully extended, working height approx. 1m. The trekking pole tripod was completely unusable that way. The Gitzo and Feisol tripods perform fine, even they are also fully extended.
PS: apologies for the poor image quality of the quick snapshots.
Appreciate the report, too bad the Leki legs don't really work. It makes me wonder whether the Novoflex poles, which are presumably built for this dual-purpose would be less flexible and work better.
jduncan
Hi there,
currently I'm facing the situation that I cannot carry heavy loads, which means I need to stay below 10kg overall weight for a multi-day tour. While I was able to optimize my hiking gear, now the largest single chunk is my camera equipment. It must come down to 2.5kg in total as a maximum. Since I really enjoy shooting medium format outdoors, it would be a big compromise to leave the camera home and go with my mirrorless Canon RP.
So I experimented with what I have:
Gitzo Traveler Tripod GK1545T 1.3kg
Hasselblad SWC/M + IQ1 60 1.85kg
Spare batteries etc. 0.5kg
Ricoh GR 0.35kg
Camera bag: 0.4kg
------ Sum: about 4.4kg
I also tried my 500CM + 80mm Planar + IQ1 60 (1.75kg), so it was about the same as above.
Now I'm trying to see where I can reduce weight.
First thought: go mirrorless? I try to avoid having two medium format camera systems for obvious reasons, so this is not really an option. Still I had a look how the weight compares to my system.
The GFX50R + V-Adapter + Planar 80 would be 1.63 kg - minor improvement, major spending. If adding the GF30mm instead of the planar, it would be 1.37 kg. Downside: quite expensive.
Second attempt: lighter tripod? This is a more serious attempt, I could add a lightweight tripod to my 'collection'.
Is there any tripod below 1kg which is worth having a look at?
Do you have any suggestions / ideas how to further reduce the weight?
Thank you!
if the situation is temporary and you are in the USA I suggest you rent instead of buying something right on. The X2D feels more Mf: the beauty and craftsmanship, the default colors that we love, but the Fuji AF is more advanced, the disponibility of lenses and accessories is far better and it's less expensive. The Fuji AF is not what you get with Nikon or Canon, let alone with Sony but it's better than the Hasselblad (the Hassy does not have tracking).
Best regards,
anyone
Best regards,
Thank you! I recovered since I started this thread (thankfully) and got both a CFV100c and a GFX100s.
There are two reasons I skipped the Novoflex poles:
(1) They are non-height-adjustable: you will need to always use them at full extension. That also means that the third tripod leg will be fully extended, and the 5 section leg doesn't look all that convincing at full height, at least if we want to use a medium format camera on top.
(2) There is a review on a German page online warning that the pole was breaking while going downhill. That is a no-go and security risk. I won't hike with those.
anyone
For the record, the Novoflex Basicpod with 5-section carbon legs worked fine on my recent hiking trip to the North. I used it with the 907x CFV100c and XCD 30. This is a very nice small hiking combo.
samogitian
I have both the Fuji GFX 100S and the X2D which I bought earlier those year. I bought the 100S first. Sure, it is more advanced. I haven’t touched it in months. Everything from the image quality to the color to the interface to the build are far superior on the X2D. As far as the imaging quality goes, I’ve never seen anything at all like the X2D. My M series is as close as the 100S, but neither is at the X2D’s level by a long shot.
ThdeDude
Speaking of the Novoflex 5 section legs, here's a 4 second exposure with a Leica S and S24mm (NOT a light camera/lens combo). It being an indoor picture, wind was not an issue. It worked quite well.
Matt
The S2 automatically does a mirror pre-release lock-up if in self timer mode. Was this also the case here?
The thecentercolumn once tested the most flimsy tripod they could lay their hands on. Might have used a mirrorless camera in electronic shutter mode, since no exterior/interior forces was acting on the camera, the consequent image was indistinguishable from an image taken with a much steadier tripod.
Pieter 12
Barry Thornton once did a test with a sturdy tripod, a sturdy tripod with mirror-up, a flimsy one and hand-held. There was not much difference between hand-held and the thin tripod until longer than 1/15 second.
John Leathwick
If I can shift topic a little away from tripods, this might be of interest to some. I've previously posted enthusiastically about my use of Mamiya RZ lenses on my GFX 100S/F-Universalis - I still think that they are great optics, but a back injury necessitating (successful!) surgery encouraged me to rethink the weight of my kit. I've interacted quite a lot on this with Rob de Loe, both as a fellow F-Universalis user, and for his encyclopedic knowledge of how to mix and match various parts to achieve outcomes somewhat outside the square. Long story short, with Rob's input, my standard 4-lens kit plus camera has dropped in weight from 6.3kg to 3.9 kg, a reduction of 2.4kg. The image below shows this lightweight kit with key components as follows:
  • Tenba BYOB 10 DLSR insert - 418 g - fits easily into the top compartment of a Deuter back pack, leaving the bottom compartment free for coat, food, first aid kit, etc.;
  • Camera body - 913 g;
  • Universalis - 1492 g - note the safety harness, prompted by a past disaster that necessitated a trip back to the factory for repair - Quelle horreur!;
  • Top right with rubber band to hold on the caps - SK Apo Digitar 35mm L-88 on recessed board - 269 g;
  • Top left SK Digitar 47mm remounted into SK B0 mount on recessed board - 229 g;
  • On camera - SK Apo Componon HR 90mm on standard M39 board - 197 g;
  • Top centre - SK Componon-S 150mm and M39 adapter - 282 g;
  • Hoods x3 - 82 g;
  • TOTAL weight - 3.882 kg
If I want to fill the gap between the 47mm and 90mm lenses, I can throw in my SK Apo Componon HR60, which in its case weighs 146 g - it uses the same board as the 90mm.
Optically, these lightweights don't always all perform to 100% of the level delivered by their RZ equivalents, but the differences mostly don't approach photographic significance in most circumstances. The bokeh of the SK 90 and 150 doesn't match that of the RZ Macro 140mm - however, the Apo Digitar 35 is wider than my widest RZ, the 50mm ULD.
Overall, my back greatly appreciates the change, and my photography is able to continue in out of the way places, with at worst a sometimes barely detectable reduction in image quality.
Finally, chapeau to Rob de Loe, not only for his ever surprising mastery of innovation and adaptation, but also the willingness with which he shares it!
-John
MGrayson
I always used 2 second delay (which includes MLU) when on a tripod. I sometimes use it hand-held with any camera that supports it.
MGrayson
  • Hoods x3 - 82 g;
-John
John,
Lovely kit, and you clearly know what you're doing. But a word of caution based on my own experience. I bent an SK 35XL out of alignment (and destroyed the mounting plate) by packing it mounted on a Cambo (with center filter attached). Because I'm an idiot.
Matt
bensonga
I am very late to this thread, so I don’t know if the OP is still looking for a system. As a point of reference I purchased a used near mint condition GFX 50R with the 35–70 lens about 18 months ago for $2500. The total weight is ~1.2kg. Combined with the OP‘s original Gitzo Traveler tripod I think this would be a compact and lightweight MF kit for hiking at a reasonable cost.
Iceman1331
In my opinion, the Hasselblad‘s 907x with the Xcd 28 p lens is the lightest traveling kit. However, 907 X does not have Ibis vs the X2d, a tripod becomes necessary on long exposure or dim light environment. It is a trade off: get the X2d without a tripod, or a 907x with a tripod.
Ai_Print
Still in Nepal about to head home but I just wrapped up a 15 day, 170 mile trek that saw 10 days above 14,000’ and one 20,000’ peak summit. I managed to catch a cold on the way to Nepal so I had that as my constant companion but all my training made up for it.
The big thing is I am really glad I opted for my Z7II, 24-70 2.8 and new 70-180 2.8 vs a small X2D kit. Between the dust, snow, wind and rapidly changing scenes, I was able to produce a lot of very nice images, the longer end of the glass being essential for building big files in stitching and superb compressed long distance shots. Charging camera batteries was a breeze as I used 10K MAH power banks with aftermarket batteries that charge directly via USB-C, no charging brick or tying up the camera for charging.
I thought I would really miss the X2D but with an outing as demanding and dynamic as this, it would not been the right tool for the job.
Maybe next time with a second gear porter?
ThdeDude
...I am really glad I opted for my Z7II, 24-70 2.8 and new 70-180 2.8 vs a small X2D kit. ....
Did you consider getting a second Z7 so you wouldn't have to change lenses - one Z7 with 24-70 2.8 and the other Z7 with 70-180 2.8 - and also would have a spare camera just in case something happened to one of the Z7? (Even if just running out of battery.)
Ai_Print
Did not consider it, I did carry on and kept everything super light and tight. I took my chances and prevailed. Normally I would have but I also needed to think of my porters and be super athletic my self.
