Hey Lou!
Responding to the "comments please" in your post:
There are a few things in your process to experiment with. I think we all do this a little differently, and there is no "best" way. In some cases, it depends on the placement of objects in the scene you are capturing. In other cases, just personal preference.
First, whether to open up the lens while doing this then stop down after: I do that all the time, but really either works. I think it helps more with wide angle lenses vs telephotos. The DoF wedge is usually quite narrow with longer lenses, so the perceived difference from stopping down may not be much when looking through LV. I say "perceived" because I still don't think the screen quality in LV on a P1 back is all that good for fine detail. YMMV. With wider lenses, it does help me to position the plane of focus more accurately, then stop down and make sure everything I want is acceptably in focus.*
Second, I recommend at least trying either 1 degree (lens < 40mm eq) or 1.5 degrees (lens > 40mm eq) of tilt before step #2. In just about every case, it cuts down on the back and forth iterations. The exception would be product photography where you are trying to do something very specific that requires dramatic tilt angles. That still has to be thought through first unless you have Gerald's CapCam.
Third, some say focus close first, others far first, then dial in tilt to get the other (far or close). I think far first makes a lot of sense because of the point I made earlier about how the plane of focus rotates, but with one caveat: I might change this to say focus high in the frame first, and then tilt to get the lower portion of the frame in focus. For this context, "high" means whatever is important higher in the frame that you care about. "Lower portion" means the same. Not necessarily the physical top or bottom of what is in view. If there is a low foreground bush 5 feet away and a tree 30 feet away that extends to the top of the frame, then a mountain off in the distance that extends 2/3 of the way up the frame, the tree to might be more important to have sharp than the distant mountain. I might want to focus on that tree, even though it is closer than the mountain. Then tilt for the bush 5 feet away.
Dave
*Note: I am pretty convinced focus shift at the f-stops we normally use to check and shoot is irrelevant. Focusing a f/5.6 then shooting at f/8 - f/16. If you are using adapters and faster lenses like f/1.4 or f/2, then I'm in the weeds on this point.
