usm
Here are two LCC shots, both are with 15mm rise. The Credo50 was mounted on a Cambo WRS with a SK 35 XL lens. The CFVii50c was on a Linhof Techno with SK 35 XL lens.
The Sensor should be the same. Both shots are showing the sensor tiling, but in a different strength. The Credo50 file is more or less the same from left to right. The file from the CFVii50c is much stronger on the left side. Which makes a 15mm shifted image harder to accept than the file from the Credo50.
because of the histogram correction there are strange colours and a lot of dust.
My question:
Why is the Hasselblad LCC so strange? Can it be a misalignment from the lens and/or from the Linhof Techno?
Usually the use of a pancake camera helps to keep the lens and the sensor aligned.
My question:
