Results 1 to 12 of 12
Thread: Schneider 5,6/47XL need Center Filter?
    Aug 2012
    1,114
    I got a nice sweet Cambo WRS package on the way, including a Schneider 5,6/47XL Lens. I'll be using it for stitching and am wondering if I need a Center Filter with that lens?
    Looking at Cambo's website there doesn't seem to be one...
    Peter
    Mar 2012
    Sweden
    1,538
    Re: Schneider 5,6/47XL need Center Filter?
    I have one for mine.
    It depends a bit on which type of digital back you have, and how much dynamic range you can accept that you lose towards the edges. If you're really picky about quality you will want one, especially if you have a modern smaller pixel back (more cast issues), but it is not absolutely dead necessary I think, although I haven't myself tried it without.
    Since you will use it for stitching it is likely that you will use it close to edges of the image circle, so I think the recommendation must be that yes you should have a center filter.
    The problem is more vignetting and more color cast the closer to the edge, and when this is corrected with the LCC file you may end up pushing several stops and get poor image quality with lots of noise on the sides.
    Aug 2012
    1,114
    Thanks torger..
    I have a Mamiya DM22 back (Leaf Aptus II 5) so I'm not even sure I'll need to do LCC.
    I will get one though and do some testing...
    Jun 2008
    SoCal
    291
    15
    Quote Originally Posted by Pemihan View Post
    Thanks torger..
    You will always need to do the LCC, but unless you shift significantly the CF is not needed on the 47XL (in my opinion).
    Cheers, -Peter
    NYC
    3,275
    7
    Thanks torger..
    You can "get away" with not using an LCC unshifted, but I think you'll find that it just makes more sense to always do it. With shift you'll definitely need it.
    I'd get the center filter. It reduces the load the LCC will have to carry regarding evening out the light which means less-pushed shadows which means more ability to use shadow-lifting for aesthetic reasons rather than just to correct lens fall off. If you don't want it for a shot (e.g. you're shooting at dusk and shutter speed is already long and you don't want the light loss of a CF) then you can remove it in a few seconds.
    Jul 2011
    154
    Do you know which one you need. I have two for sale.
    Email [email protected]
    Mar 2009
    Aptos, California
    232
    Hello,
    I've always found it necessary to use and icc when shifted, but not a center filter with the 47 (but, for example, I always use a center filter with the 35) -- FYI, I'm mainly doing internal architecture shots when shifting.
    Best, John.
    Vancouver, WA
    5,802
    564
    With my 47XL I find that I do the following:
    47XL & IQ160 - I use the centre filter religiously. It just makes LCC correction better and easier.
    47XL & Leaf Aptus 65 or P25+ - I don't need the filter and enjoy the extra speed. LCC correct well with or without the filter.
    I generally have to shot an LCC regardless of which back I use. As mentioned by others, for shifts a LCC is mandatory IMHO.
    Dec 2010
    Warks, UK
    550
    Quote Originally Posted by PeterL View Post
    Cheers, -Peter
    I thought that the significant shift ability was the main asset of the 47XL?
    Vancouver, WA
    5,802
    564
    Quote Originally Posted by dick View Post
    It certainly is one of the assets of the 47XL but there's still light fall off / colour cast across the frame. That still needs correction.
    Senior Member rayyen's Avatar
    May 2011
    Hong Kong
    608
    Agree with Graham, I use 47, 35 and 24XL.
    47 without shift, CF is not very necessary. For shift, better put CF on.
    Leica | Angenieux | Alpa | Hasselblad | Phase One
    www.raymondchak.com
    Aug 2012
    1,114
    Thanks everyone... I went out yesterday and got a center filter for the 47 XL.
    Peter
