Results 1 to 13 of 13
Thread: Any thoughts on these lenses?
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Was thinking of picking up some cheaper stuff for the lens bag for use on the Phase 645 / P45+ setup. My main glass will be the kit 80mm f2.8, supplemented by the Mamiya 28mm and the Phase/Hartblei 45 shifter.
    But these ones seem easily available and fairly cheap. I'm assuming that there's no free lunch but that some places offer a good value meal...
    Mamiya Sekor 645 50mm F4 Shift C lens
    Mamiya Sekor 645 80mm F4 Macro C lens
    Mamiya Sekor 645 150mm F3.5 C
    Best
    T
    Aug 2008
    Bruce Peninsula, Canada
    2,534
    184
    Re: Any thoughts on these lenses?
    Beware of the non-AF lenses on the Phase/Mamiya AFD III. In my case, the stop down metering does not work. (I have the 80 mm f1.9 and the 200 mm f2.8 non-AF lenses.) See page 88 of the camera's manual, which says they won't. Focussing is fine but you'll need to work with an external meter.
    Having said all that, Jack has reported that his non AF fisheye works fine...go figure!
    Bill
    23,623
    2555
    Tim not sure i would waste my money. I know there cheap but not sure how they really perform. You do need lenses that match the output of that 39 mpx sensor and not sure these will make you happy.
    www.guymancusophotography.com
    Jan 2008
    South of England
    3,295
    Thanks Chaps!
    I find that I'm generally working on a tripod and with a release anyways so loss of metering (I have my trusty Sekonic) and AF seems worth if for the bargain price of the 135mm 3.5 which I have on bid at eBay at 40 quid. I'll be ready for some compromise on IQ here since its not a focal length I'll use often, but if I can get it at this price it has to be worth trying... I hope!
    Tim
    Aug 2008
    2,534
    184
    Some of the older lenses are very sharp. The 200 f2.8 is an APO lens and is marginally sharper than the 210 mm f4 AF, which I also have.
    The 80 mm f1.9 is not particularly stellar but it is wide and I use it for star trails and auroras. (No pun intended.)
    Otherwise I agree with Guy - frankly, the lenses that one really ought to use with the P45+ are the new "D" lenses - the 28, the 75-150, the 120 macro and the new 150.
    Best of luck,
    Bill
    Germany
    3,623
    I think you can get used Mamiya AF lenses for quite good prices so I am not sure if it is worth to save very little money and to go MF lenses.
    Jan 2008
    South of England
    3,295
    Quote Originally Posted by t_streng View Post
    It's just that some of these lenses are almost free - like, less than $100!
    Surely they must be worth trying?
    Germany
    3,623
    Well , if you dont mind stopping down manually after metering, why not give it a try and see if you like them.
    I also still own 3 manual lenses but didnt like the manual handling of the f-stop.
    I just think if one spends a lot of money for a back why would you make compromises with lenses (here probably handling and optically) for a couple of hundreds €/$ ?
    Cheers,tom
    23,623
    2555
    Personally I would rather see you spend the 400 or 500 dollars and get a lens that actually is good the 55mm AF 2.8
    Aug 2008
    2,534
    184
    Hear hear, Guy! I got my 55 mm AF on eBay for $500 and it is a fabulous performer.
    Bill
    California/Thailand
    1,206
    Some folks like the 80mm f/1.9 as a cheap and fun lens. I passed on one on eBay that closed at $142 and have wondered if I'd have fun with it too.
    That said, the 45mm AF sells for relatively little money used, as does the 55mm AF as mentioned by Guy and Bill. Both are excellent lenses. I also bought a 210 ULD for quite cheap and I'm really enjoying it too. None of these are as cheap as Tim is mentioning, and I see no problem with experimenting (of course), but one of the appealing aspects of the Mamiya system for me is the opportunity to buy very good glass for quite modest prices. It seems that the older the lens series the less exciting the optics are in the Mamiya line. Coatings have been improved, etc. with each new series.
    With patience, the 45mm AF and 55mm AF can be had for less than $500 (quite a bit less) as can the 210 ULD. Of course the 150mm f/3.5 hovers around $350ish and is a must for the money IMO.
    23,623
    2555
    Dale here you go bud have fun
    http://www.keh.com/OnLineStore/Produ...BCL=&GBC=&GCC=
    Looks like they have several of them.
    California/Thailand
    1,206
    Thanks, Guy. I often forget about KEH. They've been a bit higher on the AF lenses than what a patient buyer can find on eBay, but they are reliable and consistent. For that 80mm f/1.9 they seem to be a good resource. I'd rather buy from them than trying to get lucky on eBay for something in this price range. I'll keep it in mind, but I'm really quite content with just "wondering if I'd have fun with it" for now.
    New hard drives arrive tomorrow, and I really need a new Mac Pro. Wish list is long and money is tight.
