Thank you Bart, sometimes I get a bit lucky.Another amazing series, K-H ...![]()
Thanks, K-H. Next time you better get prepared then ...Thank you Bart, sometimes I get a bit lucky.
Shutter speed was high enough.
But I didn't have tracking on.
Lock on sensitivity wasn't set high enough either.
However the Northern Flicker cooperated by flying parallel to my position.
Luckily I pushed the shutter button at the right moment.
Sony needs to implement an Olympus feature where you record only into the buffer.
When releasing the shutter button then it saves the last second or so worth of images.
I really was set up for shooting Hummers when the Northern Flicker showed up.
Now this.
A fully developed Sand Bank, right after the spot where Santa Fe takes out water for 50,000 people.
Sony ILCE-1 + FE 400mm F2.8 GM OSS.
Thanks Bart. I dunno, the Hummers leave any day now.Thanks, K-H. Next time you better get prepared then ...
About the Rio Grande, after that intake point it should be called Rio Pequeño, no ?
Kind regards.
