rdeloe
Rob.... the actual camera mounts (where the camera actually mounts to the adapter) for all adapters are very similar or identical. I do not own the Apo-Digitar 35 but do own the Schneider 35XL. I believe the rear element is much larger than the lens you have. I do not know if the lens you have will reach infinity - maybe you have FFD information and you could check against the 35XL. The recessed lens board is a real PITA. I sent mine back.
Victor B.
It makes sense that they re-used the design of the actual camera mount part. It works well.
We have almost the same lens. If you have a Schneider 35XL then you have a Schneider-Kreuznach APO-Digitar 35mm f/5.6 XL-102, which differs from my Schneider-Kreuznach APO-Digitar 35mm f/5.6 L-88 only a bit in the optics, and in the design of the housing that holds the rear cell. The diameter of your rear lens cell assembly is 43mm, which is the same as mine. Flange distance is also almost identical too, so if the XL-102 reaches infinity, my L-88 will too.
It's good to hear that it's at least possible to reach infinity. The Arca-Swiss dealer I was corresponding with about this a couple months ago couldn't get a straight answer from France. The problem of lenses in Copal shutters in tight, deeply recessed lens boards existed in the film days too. People had all kinds of clever solutions, with the simplest being extension to the aperture lever that allowed you to control it easily on a recessed board.
