Fun with MF images 2024
WOW!!!!
From this week's eclipse. The Margaret Hunt Hill Bridge in Dallas beneath totality. After days and weeks of increasingly dismal weather predictions, patchy clouds partially obscured the C1-C2 cycle—making it more interesting, as Matt noted above—and then the sky broke clear though hazy shortly before totality. The dimming light tripped all the bridge and street lighting. it wasn't quite the image I had planned, but it was close. And it was spectacular in person.
P1 XT IQ4.150 | Rodie 32
River Tees...
GFX100s, Canon 70-300mm f4-5,6 L IS
Dallas' Reunion Tower & Hyatt Regency the evening before the eclipse. This is a 12-image stitch. My prospect and the POV compelled the use of the Mamiya 300 and building up, rather than shooting the Rodie 32 and cropping.
P0011154_Panorama 1 copy-FrameShop copy_JPEG Quality 95_ReunionTowerSunset 1.jpg
P1 XT IQ4.150 | Mamiya 300
There's a Mamiya 300 in an XT mount? THAT makes me more interested in the XT than anything else. Weird, I know. (GREAT image, BTW! Not a flat stitch, I presume....)
Matt
Matt
Thanks Matt, more of an overstitch. ;) It's got some artifacts I may see if I can avoid by stitching manually in PS rather than auto in C1 [C1 is pretty darn good; I just wish I had more control].
Anyway, that's an old film-era Mamiya 300 ULD C on a Cambo 645/XT adapter. I have two: the small f/5.6 for air travel, which produced this image, and the honkin' big 2.8, which I prefer when I can. It's sharper, and unlike the quite good Mamiya Auto 300 f/4 [for which the aperture is electronically controlled and could be used on my Phase XF], it has a manual aperture control and is quite effective on the XT.
Ahh! I'm also a huge fan of the 300/5.6 ULD. The 300/2.8 APO is just too heavy - as wonderful as it is (and I use its little brother the 200/2.8 APO), I know I would never take it outside. Anyway, apologies for dragging us a bit OT.
Today I went out to test my newly acquired SK Apo-Digitar 5.6/35 XL.
This is the third shot I've made with it, my CFV-50c Mk1 and my Cambo WDS, in Berlin (Germany):
No rise/fall and no shift. CF on the lens and LCC applied.
The linearity of this symmetrical design is palpable, it gives a totally different feeling to the images than my Hasselblad 40 IF, even after software distortion correction applied to the 40 IF. I'm together impressed and perplexed! 😅
As for the sharpness, I have a clear misalignment somewhere. The center is perfectly in focus, the right side is pretty good but the left side is slightly smeared/out-of-focus.
I need to test more in order to understand whether it is a lens internal misalignment of whether it is my digital back interface that is not shimmed correctly, although I must say that I never noticed this when using my V lenses on the WDS.
Anyway, I like this image, as it has something surreal in it. Recently I started to like to always inject a surreal atmosphere to my images.
You may wonder why the heck I've acquired the SK 35 XL when I have a really badly compatible digital back? Well, because I'm waiting for the PDAF issue fix in order to switch to the CFV-100c. So, cross fingers!
The linearity of this symmetrical design is palpable, it gives a totally different feeling to the images than my Hasselblad 40 IF, even after software distortion correction. I'm together impressed and perplexed! 😅
I had an SK 35XL. It was knocked out of alignment (badly enough to warp the Cambo plate) and was never again sharp on both sides even after two repairs. Yes, it was my fault. The Center Filter stuck out beyond the Cambo protection bars and gave a large lever arm on the lens mount. It is, as you say, an extremely linear lens, so I hope you get your alignment issues fixed.
Concrete melancholy. The remaining structure of a brutalistic architectural building (arch. Geo & Dirk Bontinck) from the seventies waits patiently for the moment when it will be repurposed as a residential building covered in a glass shell. The full process will take five years. Shot in Gent, Belgium, with an Arca Swiss RM3di, an IQ4 150, and a Schneider-Kreuznach Apo-Digitar 5.6/43XL at f/11 and 10mm rise. Still learning how to work with a technical camera, it's a very pleasant way to make photographs.
The 35XL is a finicky lens. I've owned mine for a long time and many years ago sent it back to Schneider for alignment. Mine happens to be in Alpa mount but is easily disassembled for use in any other mount. It's always the copal that is the culprit when there are alignment issues. When mounted on a pancake camera the copal must be perfect or there will be skewing.
Once you get beyond all of that you have to deal with the curvature of the lens which can't be fixed until f11. I'm surprised that you had to use distortion correction as the lens actually has almost zero distortion. I have found that at f11 with everything in alignment wonderful images can be had even with some shifting.
I have had better success focusing at the edges at the taken aperture vs. focusing at the center. Always check your edges!
I have a 907X 100C arriving soon and will be testing the 35XL on my Cambo Actus and am hopeful for good results with limited movements.
Victor B.
Let's see. I've informed to the seller. I've also sent an email to Cambo EU to know whether they can eventually align it and at which price.
The alternative is to return it to the seller. It's a pity because it really looks in mint condition.
