Nice shot!My first photo with the widest lens available for the 44x33 medium format sensor size, the Venus Optics Laowa 17mm f/4 (~13.5mm in 35mm full frame terms). This was taken this morning at Yaki Point in Grand Canyon National Park...
GFX 50S, 17mm, ISO 100, f/8, 4s
The center is very good and there's a little falloff into the corners but it's better than I expected and better than the 12mm f/2.8 coupled with the Laowa Medium Format converter - that combo has essentially the same optical formula but by eliminating the mount between converter and lens, the corners are more consistant with each other (at least with my lenses). I have basically only used the lens on one shoot so far but I did do a quick and dirty centering test and did not find any decentering and, as I said, the corner resolution falloff was better than I expected on the ISO test chart. It is much better, for example, than the Nikon 16-35 f/4 at 16mm on a D850. Hope that helpsNice shot!
How do you find that the lens performs all round, including into the corners? (Hard to judge from web presentation)
E.J., thanks for your impressions. I've heard good things about the performance of this lens and wondered if it is adaptable (in my case) to other MF systems like the Pentax 645 MF cameras? As an aside, I was never personally a fan (and stated often here years ago on Getdpi) of the Nikon 16-35mm f4, primarily due to its excessive distortion and other anomalies I observed. Again appreciate your observations.The center is very good and there's a little falloff into the corners but it's better than I expected and better than the 12mm f/2.8 coupled with the Laowa Medium Format converter - that combo has essentially the same optical formula but by eliminating the mount between converter and lens, the corners are more consistant with each other (at least with my lenses). I have basically only used the lens on one shoot so far but I did do a quick and dirty centering test and did not find any decentering and, as I said, the corner resolution falloff was better than I expected on the ISO test chart. It is much better, for example, than the Nikon 16-35 f/4 at 16mm on a D850. Hope that helps![]()
I don't think that would be possible, at least not without some very complex optics as the flange distance on the 645 is dramatically longer than on the GFX. It's easy adapt from a long flange distance to a short one as the adapter just makes up the difference but going the other way is not at all easy.EJ, thanks for your impressions. I've heard good things about the performance of this lens and wondered if it is adaptable (in my case) to other MF systems like the Pentax 645 MF cameras? As an aside, I was never personally a fan (and stated often here years ago on Getdpi) of the Nikon 16-35mm f4, primarily due to its excessive distortion and other anomalies I observed. Again appreciate your observations.
Dave (D&A)
Thanks for that! Are you in a position to compare its performance with the Nikon 14-24 used at 14mm on a D850? For me, that's the key comparison because not only are the focal lengths (angles of view) more similar, but its also a stronger competitor... The 14-24 is superb at 14mm (by the standards of such systems).The center is very good and there's a little falloff into the corners but it's better than I expected and better than the 12mm f/2.8 coupled with the Laowa Medium Format converter - that combo has essentially the same optical formula but by eliminating the mount between converter and lens, the corners are more consistant with each other (at least with my lenses). I have basically only used the lens on one shoot so far but I did do a quick and dirty centering test and did not find any decentering and, as I said, the corner resolution falloff was better than I expected on the ISO test chart. It is much better, for example, than the Nikon 16-35 f/4 at 16mm on a D850. Hope that helps![]()
I used to own that lens with a D810. The Nikon has a lot more linear distortion as that is it's weak point and the strength of pretty much all of the Laowa lenses. The 14-24 is probably a little bit sharper deep though into the corners.Thanks for that! Are you in a position to compare its performance with the Nikon 14-24 used at 14mm on a D850? For me, that's the key comparison because not only are the focal lengths (angles of view) more similar, but its also a stronger competitor... The 14-24 is superb at 14mm (by the standards of such systems).
By the way Ed, one of the strengths of this lens is that it actually takes screw on filters. 86mm but I have some 95s from my Phase One days that I just step down to 86. It works well for a single filter but if I stack two it does vignette a bit.Thanks for that! Are you in a position to compare its performance with the Nikon 14-24 used at 14mm on a D850? For me, that's the key comparison because not only are the focal lengths (angles of view) more similar, but its also a stronger competitor... The 14-24 is superb at 14mm (by the standards of such systems).
I really like this one Alan. Vertical composition, simple color palette, path leading to the tree(s) with yellow leaves remaining... Well done sir.Weardale...
.Interesting! However, as a Pentax 645Z user, it's not an option for me :-(
Beautiful Alan !! and that Tamron 90 SP 90 Macro (I guess its the new version - F017N ?) is doing really fine even on MF. I found it sharper than the 100/2 Zeiss Makro, so one shall not underestimate the Tamron 90 macro.Cold and frosty this morning, but I did manage to find some colour....
(Weardale)
