mristuccia
Indeed, the CFV I 50c user guide contains this note.The chart refers to the manual for details which says:
Although the SWC/M, 903SWC and 905SWC models work in conjunction with a CFV-50c, the combination is not recommended for critical work in certain instances. It is difficult to predict all photographic situations so it is advisable to read the following and make a judgement followed by checking the focus on the preview to see if it matches your expectations.
The Biogon 38 lens was designed for film use where the unusually close proximity of the lens to the film plane was of no consequence. However, digital sensors and their protective filters make very different demands on the angle and travelling distances of the peripheral rays exiting the rear lens element. Gradual unsharpness consequently occurs towards the edges of the frame, particularly noticeable with flat subjects (typically copying situations, 90° shots against building façades, etc) though these effects will be naturally less obvious with more three-dimensional subjects. Slight green and magenta casts are also caused, though these can be removed digitally in Phocus.
What I was saying is that in the user guide of the CFV II 50c HB seems to have removed this warning note, as I don't see any mention of it anymore. The new back's user guide has even a dedicated section on the interoperability between the CFV II 50c and the SWC cameras (Sec. 5.12 page 54), and no mention of any quality issues is found over there. I find it strange because both the old Mk 1 and the new Mk 2 use the same sensor.
