Never tried myself, but I think you could also consider trying specialised ingestion utilities like Photo Mechanic (https://home.camerabits.com/tour-photo-mechanic/) which ingest the files from the SD into a disk folder by applying renaming rules and EXIF/IPTC data like author/copyright while importing.Question for you all (as well as the X1D owners).. Is there a way to change the file prefix from B000? I'm running into a situation where my X1D II and my CFV2 are starting to overlap in file numbers.. which causes an issue on export as I export to folders by format / resolution / quality, and I don't make any adjustments to the file names when I export.
With my workflow it's heavily directory structured, so I copy files from the SD card via finder, I don't do any special app import process that would append or prepend a new prefix/suffix..
I'm just kind of amazed if this is the case and Hasselblad has not yet allowed for changing the file naming format.. hopefully I'm missing something here.
If you're using Phocus or LR, I see little point to including camera and lens information in the file naming schema. It just complicates the file naming too much, and that information is all in the file metadata easily found by the apps.Thanks, Vieri! I will look into that.. it sounds like our workflow may be somewhat similar.. I do not like for any program to "import" my photos, I manually copy them from SD card to a set of folders I create for each import. Thanks for the tip!!
Edit- WOW! This looks great, Vieri! Out of curiosity, would share your file naming standard? I see it can use EXIF data to build the file name which is perfect.. I'm wondering if including camera and lens information in the file name is too much..
<YYYYMMDD>_<LOCATION>_<SHORT-DESCRIPTION>_<ORIGINAL-RAW-SEQUENCE>.fff
20200818_BERLIN_BirthdayOfMarco_B0001234.fff
--\YYYY-MM-DD.LOCATION.DESCRIPTION
------\01. DESELECTS
------\02. SELECTS
------\03. RAW PROCESSING
-----------\EXPORTS (**symbolic link to ..\04. EXPORTS)
------\04. EXPORTS
Hello Brandon,Thanks, Vieri! I will look into that.. it sounds like our workflow may be somewhat similar.. I do not like for any program to "import" my photos, I manually copy them from SD card to a set of folders I create for each import. Thanks for the tip!!
Ahh! Jealous!Here are two photos of the new grip für the 907 se...
The grip is a perfect addition to the 907 setup ( in my eyes a must have...), nice handling , configurable buttons and an af-d button that i really missed .....
View attachment 151010View attachment 151011
Best regards
Henning
Ahh! Jealous!
Would you mind measuring the new width of the camera with the grip attached? I'm curious just how transportable it will be in a bag with the grip attached.
Looking forward to receiving mine!Here are two photos of the new grip für the 907 se...
I went with the B+W Wide Metal Lens Hood in 67mm for the 45P:We all seem to have that Sioti lens hood on our 45P
With respect to the L2 bag, I'd just lay it into the bag grip side up. There's enough height to handle that.Ahh! Jealous!
62mm filter thread on the 45P. I always get mixed up because the 21mm has a 67mm filter thread.Godfrey,
What is the size of the B+W hood--62mm or 67mm?
Like your new bag! Looks perfect for your kit!
Thank you.
I don't like using filters unless I am using them to filter light for a purpose. For me, a lens hood protects the front element of the lens and always provides a little additional protection from flare.Have you guys felt a need for a hood for image purposes, or just for general protection? I don't think I've run into a scenario yet where it's flared badly, or that I felt a hood was really necessary. I do have a B+W UV filter on there to protect the front element, but that's it.
Circumstances like that are a good reason for a protective filter ... I have some sizes in clear optical glass for that.As I live by the seaside I tend to rely on UV filters, they are usually way easier to clean than the lens front element. The downside is they can cause additional flare or reflections, hence the mandatory lens hood.
The B+W wasn't available when I got the lens, and some people mentioned vignetting issues when used with a filter. It looks good though !
I use hood instead of protective filters, except when I am close to dust, salt, or similar factors.As I live by the seaside I tend to rely on UV filters, they are usually way easier to clean than the lens front element. The downside is they can cause additional flare or reflections, hence the mandatory lens hood.
