Here you can see the adapter for the ALPA STC and for the LEE standard bellows .
Have a look to the reworked rod , which allows you to turn the camera by 90 degrees and the bellows holder will stay in place .
But the ARCA bellows still work fine with the RODIE 40mm .
I do not claim that my bellows system is perfect , but it fits my needs
so far . If I should encounter situations , where it needs further modifications , I will do them .
Have a look to image two .
The front and rear ends of the rod are reworked to have a flat part .
Here the screws can hold the rod and prevent the rod from turning .
I have the HR-DIGARON 28mm lens , but never do any shifting with that lens . The possible shift amount is very small anyway .
My next focal length is the HR-DIGARON 40mm .
If shift is required , I can use the ARCA bellows because that hood can easily be moved into proper shading position . Have a look to image three with the ARCA bellows .
Unfortunately , the ARCA bellows can not be turned .
But the LEE bellows can , but it is not required for the standard type , because that has a square form .
The LEE standard bellows are wide enough to properly shade most of the movement . My CFV-50 sensor is 37x49 . That makes things easier .
Horizontal and vertikal .
Please keep in mind , that I wanted to use as much available gear as possible .
The PLS fits very well to the 28mm RODIE .
I can't speek for the 23mm RODIE . I have never had one in my hands .
