SIGMA SD1 shots
scho
The chippies are out foraging again. SD1M 17-50 Heavy crop.
Another shot that was upsampled 4x in Topaz AI Gigapixel and reduced 50% for upload to Flickr.
scho
A couple from a walk along Upper Buttermilk Creek with the SD1M + 30/1.4 A
Old oxbow pool on upper buttermilk creek with some marsh marigold in blossom.
Sphagnum moss growing on dead tree stumps
scho
Inspired by Graham's recent shots with his modified DP1M. Sigma SD1M (IR cut filter removed) and Sigma 30/1.4 Art lens. Cornell arboretum overlook. I had to replace badly blown out sky/clouds using Luminar 4.
scho
Last one for today. Purple Oxalis plant produced brilliant red leaves shot with the SD1M 17-50 with green filter and Foveon Classic Blue color mode in SPP. The HSL sliders in LR are very useful for making targeted hue and saturation adjustments. I try not to adjust white balance (custom set in camera). Thanks again to Graham for the green filter workflow suggestion.
ggibson
Looks great! Finally a use for Foveon Blue mode, eh?
One thing I’ve noticed with my recent photos is a slight cyan vignette in the corners. I think I see a bit of that in yours also. I’m not sure if it’s due to the green filter specifically or it could be from SPP processing color without the IR cut filter.
Have you managed to get the dark skies and white foliage look in B&W with the Merrill in IR? That’s something that I find difficult to achieve.
scho
Yes, I've noticed a little cyan vignette as well, but not too bad. I haven't tried any B&W yet with the SD1M and green filter setup, but I will today or tomorrow now that the humid air mass here is finally departing.
scho
I see what you mean about problems getting a deep black sky. Best I could do today with a clear blue sky was a dark grey (image below used green filter and a CPL). I used to shoot B&W with the SD1 by extracting the blue channel from the x3f files with RawDigger, but that would not help with this issue.
ggibson
A 720nm filter and CPL is the best combination I've used so far for dark sky/white foliage. I played with the B&W color mode on my DP1m today, which shows the preview in B&W on the screen, and it was much easier to see the results while shooting. I realized that my workflow for B&W has always been to export in color from SPP and convert in Lightroom, but perhaps there is more control in SPP since it is reading the RAW.
