MGrayson
It's a great piece of kit. And this is the base model. You should see the micrometer equipped versions!that little dial on the macro rail looks very cool.
this the one? http://www.hejnarphotostore.com/product-p/ms5p-10-ks.htmIt's a great piece of kit. And this is the base model. You should see the micrometer equipped versions!
Almost Exactly. Mine is the ms5p-8-ks.
What are you using to connect the two rails?A friend just picked up an RZ67 and is shooting some film. That got me thinking about using a macro setup instead of a flatbed scanner. Before I knew it, the pieces were all in place. (Surprisingly, I had a light table squirreled away somewhere). So to test it out, here are two shots titled 6:00 AM and 6:05 AM
Leica S3, S120/2.5 (by itself, so 1:2 magnification). Gitzo 5 with leveling base, Novoflex clamp, Hejnar rail and Macro rail.
Matt
The horizontal rail is actually a long lens support (which I needed anyway). The "tiny" clamp at the end that normally holds the Y-shaped support piece is strong enough for this. Well, Hejnar said it "might" be strong enough, but advised against it. Under the panorama section, he has a corner support piece that holds a bracket REALLY firmly against the end of a rail, so I'll be using that when it arrives. (VR8-625). If I didn't love overkill, I'd be using the Fuji X for everything.What are you using to connect the two rails?
Jesse,
Thank you Matt. From memory, polarizer and 6-stop ND, exposure 16 seconds.Jesse,
Lovely. Filter? Exposure? Just curious.
Matt
Gorgeous images! I guess I should have been paying closer attention to why you guys were seemingly stuck in that grove...On our last day together in Colorado, we found a lovely road near Mount Wilson that just kept going and going. We left the second half of the road for another year's investigation. It had one spot with a thick grove of aspens. This is the same location from which @jng and @diggles posted images. Both of these images have ~15mm lens rise. As usual, it took a while to wait for the right combination of cloud cover and wind breaks. The woods were incredibly dense; there were almost no sky holes to touch up.
I was the last one to duck in the car as it started to rain.
Here is the ominous sky just before we headed down.
Dave
Thank you, Victor! I am shooting a lot of waves while I am recovering from a knee injury, it’s about as far as I can walk at the moment with my backpack.Hi Greg.... good to see you are having a good time. I really like your last image as I have begun to more appreciate the movement of waves with just a little bit of smoothing. I am going to start to practice more with shorter time frames.....
No matter what all images look great.....
Victor B.
