No vignetting after applying the LrC correction that I mentioned above or processing with Phocus (raw files).No vignetting also?
tried the files in Phocus 374. With the lens corrections (no LCC) there is a very little magenta cast. When adding the LCC with JUST the "remote cast" button on it is perfect.For anybody who's interested, here are some Dropbox links (3F format):
Test scene XCD 4/28P at F4
White LCC target for Phocus Scene Calibration (XCD 4/28P at F4):
Support for 28p was added in n 3.75. You tried it in Phocus 3.74 that is not supposed to support 28p yet.tried the files in Phocus 374. With the lens corrections (no LCC) there is a very little magenta cast. When adding the LCC with JUST the "remote cast" button on it is perfect.
But when the lens is also build for this "old" sensor it should work without the LCC!
sorry, wrong computer but same thing with 375...Support for 28p was added in n 3.75. You tried it in Phocus 3.74 that is not supposed to support 28p yet.
I made the same observation, hence creating an LCC for the old gen cameras is currently the only proper solution.sorry, wrong computer but same thing with 375...
I consider D+15, V+92, 50 - +8 distortion leaves too much barrel distortion for me. But while +15 is better it is still not the best.I have created a temporary LrC profile for the XCD 28p images:
- Distortion: +8
- Vignetting: Amount +93, Midpoint 0.
Well, *I* like the 28mm focal length more than the 30mm. I'd prefer 26 or 24, but even the slight extra FoV of the 28 is a plus.11 sites and not much talk about focal length.
I find 28 quite more interesting than 30mm , and 21 I often found somewhat too wide.
thats why I am interested in this lens more thabthe 30 which I won and which is great, but I often wish for something a bit wider.
I have also noticed the 28 AF doing a poor job, even at infinity. But I've been using magnified manual focus check ever since sensors got to be more than 24MP. Still, it's surprising, given that mirrorless is always supposed to AF perfectly .I think one of the difficulties with the 28P not producing the perfect acuity like the 21 is due to the focussing stepper motor. I find it difficult to be sure through the viewfinder of the X1D to nail the best DoF even if it is a rather long focal length at F4. Essentially, one has find the optimal focus point 1/4 off-center and check everything in-between to achieve best DoF. My guess is the individual steps of the focussing mechanism are rather coarse, which makes you think the center is in focus but overall one has not nailed the best DoF compromise. This is turn reduces the overall impression of sharpness throughout the scene. YMMV, I am assuming very demanding work.
In urban settings this might not matter as much, but in landscape it does. On the other hand, the 28P lens elements are so tiny that the AF is rather quickly done and the camera confirms focus.
Given the above, I prefer to go MF with the 28P for landscape scenes.
With respect to focal length, I am a 90 deg. diagonal AoV guy, so the 28P suits me well and further cropping adds even more flexibility.
I think Hasselblads focal length choices are spot-on for the intended uses they advertise. The 28P is not for everybody, I guess.
It's by wire, but the response varies smoothly enough that I don't have a problem rocking back and forth over true focus. I'll try a few other XCD lenses - I don't have the 45P or either of the V lenses, alas.Matt, is the 28P MF by wire or mechanical ?
I did one when I first got the 28P, it was against my friend's 30mm. What we both gleaned from that was that my friend's 30 is completely out of spec, the 28 made a mockery of it. As far as I know, he sent the lens in to Hasselblad.I wish I could see a 28 vs 30 f8 sharpness test on an x2d . Hasselblad’s own MTF data doesn’t look too encouraging ….
I no longer have the lens, my XCD 30 images are from Banff, and it's a long drive to do the comparisons. They are exceedingly sharp, but then so are the 21, 45, and 90 images.I wish I could see a 28 vs 30 f8 sharpness test on an x2d . Hasselblad’s own MTF data doesn’t look too encouraging ….
