k-hawinkler
Well, in that case rolling electronic shutter distortions. End of interest for me.My guess is that the Z6 has the A7III sensor and I expect similar performance.
... but mechanical tear and wear....and by the way shuttersound very quiet and soft in appearance..a nice sound
I forgot to ask about a electronic shutter, while I will go mechanic..... but mechanical tear and wear.
Mmm, I don't know I might still be interested though ...Well, in that case rolling electronic shutter distortions. End of interest for me.
Yes to having electronic shutter but it’s limited to the same 1/8000 shutter speed at the mechanical one. Perhaps they can add faster electronic speeds through firmware in due time. I have not read anything on readout speed yet but I wouldn’t expect A9 performance because that likely would’ve been highlighted and in a sense - huge to have that performance for $2k.Question:
Do the 2 cameras have an electronic shutter?
If yes, what’s the sensor readout time?
1600 jpgs and the battery (not the camera died!) drained, right?DPReview reported that they got nearly 1600 shots on one battery and did a few 4K clips on that same charge before the camera died.
Smaller/lighter than Sigma ART FE 50/1.4 ? :grin:Mmm, I don't know I might still be interested though ...
The problem with the CIPA standard is that it requires all camera functions to be active. I never use WiFi or other radios or even the LCD when taking photos, so maybe the batery life wouldn't be so bad anyway. I used to get 2-3,000 images from one charge when using the D810.Yes to having electronic shutter but it’s limited to the same 1/8000 shutter speed at the mechanical one. Perhaps they can add faster electronic speeds through firmware in due time. I have not read anything on readout speed yet but I wouldn’t expect A9 performance because that likely would’ve been highlighted and in a sense - huge to have that performance for $2k.
One other thing I read after digging around a bit is that AE for continuous focus is limited to only being available when shooting at 5.5fps or slower so the 9fps is a bit deceptive though technically accurate. So in reality what we have is something that’s still closer to A7RII levels (if has 5fps continuous focus) with AE. I haven’t found more information on the Z6 as most everyone is focusing on the Z7 for obvious reasons of being the “flagship.” Now regarding battery life perhaps it’s better than advertised at 330 shots for the Z7 (310 for Z6). DPReview reported that they got nearly 1600 shots on one battery and did a few 4K clips on that same charge before the camera died. They didn’t say if they turned off all the internal radios (or maybe I overlooked that part) but if this is accurate then perhaps the battery life will be comparable to the generation 3 Sony cameras.
This is really turning out to be the exact camera I expected - which isn’t a bad thing at all. Just typical.
Why should it? Nikon and Sony have never had similar performance when using the same sensors earlier.My guess is that the Z6 has the A7III sensor and I expect similar performance.
Well yeah. The battery drained. My bad. That would be a different discussion about testing cameras being bricked upon use.1600 jpgs and the battery (not the camera died!) drained, right?
Well it’s only a problem in a sense that cameras may not have the same features. I guess it would be helpful to test and rate in airplane mode and with the features turned on.The problem with the CIPA standard is that it requires all camera functions to be active. I never use WiFi or other radios or even the LCD when taking photos, so maybe the batery life wouldn't be so bad anyway. I used to get 2-3,000 images from one charge when using the D810.
I’d assume some updated version of the D750 sensor but maybe it’s a version of the A7III one.Why should it? Nikon and Sony have never had similar performance when using the same sensors earlier.
Now, I for one didn't expect anything at allYes to having electronic shutter but it’s limited to the same 1/8000 shutter speed at the mechanical one. Perhaps they can add faster electronic speeds through firmware in due time. I have not read anything on readout speed yet but I wouldn’t expect A9 performance because that likely would’ve been highlighted and in a sense - huge to have that performance for $2k.
Well that’s always been the dilemma that this camera doesn’t fully solve for all. This camera is a great option for Nikon owners that want to add more capable video ability while maintaining commitment to the Nikon ecosystem, want to maintain a DSLR as their primary system, or want a smaller kit for personalized photos.I like it, nice to be able to use the D8xx batteries since "Nikon photographers" will use both systems. And I won't miss dual card slots, it's not like the old days of PCIMA cards. I still wish the lenses were smaller so it was "jacket pocketable" but that's just normal camera manufacturing cluelessness.
Yet otherwise by virtue of having the new lens mount there is less reason that a "Nikon photographer" with a large investment in DSLRs and lenses needs to remain brand loyal. If my goal is to have a professional full-frame style walk around compact camera with a couple of fast prime lenses then even though I may have $10k of Nikon gear there is still no compelling reason for me to be loyal to Nikon other than maybe the UI will be somewhat consistent. But IRL I'd probably use whatever brand offers the best value overall.
And that points to the larger question. Will Nikon transition to this as their main, professional lens mount going forward? Obviously a S-lens won't work on a DSLR which implies ultimately abandoning the DSLR. Seems like a way to plant doubt, if not now but in a couple of years, they will have to explicitly tell us what their road map is.
I didn’t want to expect anything but I’ve been around enough big marketing campaigns first hand to know when a company is about to play it safe and deliver what will underwhelm people in regards to how much hype they drive. It’s almost is a no win situation for every company that does it but yet they continue to do so because no publicity is bad publicity... but after the publicity has worn down what you’re left with is a capable product (in most cases) that could never possibly hold up to the promised fan fare.Now, I for one didn't expect anything at all
But so far to me it looks like a real little cracker and though we have to wait and see what the usual suspects come up with, but for a first series I think Nikon did well.
Details that I like are the lens mount being off set more to the outside (more room for your fingers) and that little top LCD ... :thumbup:
Will I buy one ... :grin:
