Nice ! If you would like a bit more ’dynamic range’ you could try a higher ISO film, with my scanner software, Silverfast, there is also a possibility to ’trick’ the distribution and inversion curve by using different film ’profiles’One of the first large format images I have ever exposed...on my new (to me) Sinar X with Nikkor W 180mm f.5.6 lens. Shanghai GP3 4x5 film developed with Ilford ID-11. Scanned with Fujifilm GFX 50S II with Hasselblad HC 4/120.
The location is Suntec City's Fountain of Wealth. Very long exposure, metered at 30s at ISO 50 at f/16, but after reciprocity failure compensation, the film was exposed at 1m 26s. Developed at ISO 100 box speed.
I have decided I will never do color negative or slide sheet film, due to the cost. Color film is certainly NOT for experimenting. But black and white film is good for experimenting. My favourite film is Fomapan 100 (Czehia) because I can get it super cheap. That film can also be had in 200 and 400 for experimentation.Thanks Martin...Yes, more dynamic range would be nice. I find the negative to be quite thin...and after scanning, the histogram is a bit scrunched up in the middle. Here is another image I took. This one is even longer in exposure, I need to look up my notes, but my memory says its about 4 minutes after taking into consideration reciprocity failure of the GP3 film. I am playing with the GP3 as my first box of film as it is rather inexpensive...working out to about USD 1.50 per sheet of film plus developing chemicals.
I think there is a bit of a light flare on the right of the photograph probably through the lens. Also the image is not critically sharp, as I realised after the fact, that the bridge I had the tripod on was not completely rigid, and vibrated when pedestrians walked by.
What are faster films for 4x5? HP5? Portra 800 is a bit expensive at this stage of experimentation, though I have a box of Provia in the freezer.
I love nights shots in B-W also.Thanks Martin...Yes, more dynamic range would be nice. I find the negative to be quite thin...and after scanning, the histogram is a bit scrunched up in the middle. Here is another image I took. This one is even longer in exposure, I need to look up my notes, but my memory says its about 4 minutes after taking into consideration reciprocity failure of the GP3 film. I am playing with the GP3 as my first box of film as it is rather inexpensive...working out to about USD 1.50 per sheet of film plus developing chemicals.
I am going through this speed dilemma myself, with my handheld homemade Sinar Norma Handy 4x5. I have been using Ilford HP5+ in bulk 35mm rolls, shooting it at EI 1600, but developing according to Ilford's recommendation for EI 3200. This works VERY VERY WELL in 35mm, I can't imagine why it won't work, scaling it up to my need for high speed 4x5 with great tonality. Another I'm going to try based on LFF recommendations, is FOMA 200, pushed to EI 800. Will be interesting to see the tonality differences between the HP5+, and the EI 800 Foma 200. Wish something faster than 400 was made in 4x5, but I am pretty sure this will work for me. You might want to try something similar, EI 100 is pretty darn slow. Pushing HP5+ to EI 1600 with quality is not a big stretch at all. Another possibility is Kodak TMX400, I just bought 50 sheets, to shoot against the HP5+. But WOW it's 'spensive, Four Bucks a Sheet. EEK!What are faster films for 4x5? HP5?
