Technical Camera Images
vjbelle
It really is best on a pancake camera to shim the back so that all lenses focus beyond infinity. A hard stop infinity focus with a helical is something that can vary with temperature swings. If you happen to own any lens that has an infinity stop that cannot be adjusted on the lens( such as the Schneider 150mm ) then shim that lens to go beyond infinity and hopefully all other lenses will also focus beyond infinity. If not then adjust those lens rings.
Don't lose any of the small helical screws.....
Victor B.
mristuccia
The SK focus ring was calibrated by Cambo to reach infinity at the specification plane of the digital sensor.
However, you can re-achieve infinity focus with your reset sensor position easily. Loosen the three small screws located within the grip area of the focus ring and then carefully turn the focus ring firmly against the infinity stop, which will move the infinity stop rearwards relative to its current position. Retighten the screws and, using your live view, confirm that the lens can now be focused at infinity.
My preference is to be able to turn the focus ring about 5mm beyond infinity, which allows the point of exact focus to be found visually on the live view at 100% by turning the focus ring back and forth.
Rod
I do the same thing. We lose a little close focus ability by extending the helical beyond infinity, but I'm happy with that trade off.
Dave
Thank you guys. GetDPI is a never ending source of knowledge. :)
I'll try. And I agree, setting up a reach which is a bit beyond infinity is better for focusing, especially on backs with live view.
mristuccia
Victor B.
That I will do first, but I think I'm already as close as possible right now.
usm
I'm trying to understand the limits of the SK 35XL on my CFV-50c.
This is a vertical stitch of 3 horizontal images taken at center, at 15mm fall and at 15mm rise on the lens.
Cambo Wide DS digital, SK 35XL, f11, center filter and LCC applied.
I still have problems achieving the correct focus. Now it seems that I reach the end at infinity on the lens ring but the image is still front focused, more on the tree at the bottom-central part than on the buildings behind.
I've shimmed the digital back interface to make the lens focus on a perfect horizontal plane, but it seems now that this shim has moved the back too far away and I cannot reach infinity focus anymore.
Everything is still working-in-progress here... 😬
Anyway: Berlin, Westhafen
for me, it is too small to see it.
But you said that you shifted 15mm in both directions?
With the center filter and LCC?
Are you using Phocus, C1 or Lightroom for the raw files?
I have the same combo (lens and db) on a Arca Swiss Factum. When shifted 15mm I will get some pattern which are just viewable in 100%. They are not completely corrected with the checkerboard filter in Phocus. In this example I moved the histogram to make it better visible...
As ich asked you already in the other thread. If you have time to send me raw files of a 15mm shifted (short side) LCC with and without center filter, I would be very thankful.
mristuccia
As ich asked you already in the other threat. If you have time to send me raw files of a 15mm shifted (short side) LCC with and without center filter, I would be very thankful.
The reason why I did not share it with you yet, is because I want to shot a series with and without CF.
I only have the one done with CF right now, but I will share the files with you in PM by the end of today. Maybe the ones with CFs areenough for your need.
I hope I can do the full set (CF vs no CF) next week.
By the way, I used Phocus for the above shot. And I overexposed the LCCs by 2 stops in respect to the real shot exposure.
Best
Marco
  • Like
Reactions: usm
dchew
Another great day was in El Chalten, hiking Sendero Fitz Roy. The colors that morning were from another world. I'm sure this image will evolve; it is one of those cases where I'm struggling to figure how far to tone down the colors since what we experienced looks beyond neon. The sky hues were bouncing throughout the canyon highlighting the fall color. An incredible sight. Sk60xl with some tilt, Alpa STC, IQ4 150
The second image is upstream about 45 minutes later. Same setup. Sorry, 35xl for the second image, and no tilt.
Dave
dchew
Just great, Dave!! How long and difficult are the hikes?
Victor B.
Thank you, Victor. They were about 10k in, so a total of about 11 miles both ways. The first one in Chile a little more, the one in Argentina a little less. Snow made the first one a little dicey coming back down. One of the three of us had no hiking poles, so we shared; it was turning to ice as we descended from temperature and compaction.
I do highly recommend them both. They are different experiences. The Chile hike is basically the destination. Not much image making along the way. The Argentina hike is much slower because you are constantly distracted. Justin and I could have spend a week in that valley, and we didn't see a fraction of what we could have seen.
Dave
usm
Best
Marco
Thank you!
short answer, don't want to mess up this image thread. I can't see the pattern in your files.
The reason could be:
1. The center filter.
2. My possible misaligned lens
that's why the LCC shots without CF is important for me.
But there is no rush!
Greetings, Mario
Steve C
Dave
You are living your John Muir quote. Fantastic work!
mristuccia
Thank you!
Greetings, Mario
Let's continue in the private conversation, unless you feel your issue may be helpful to the whole community. In this case my suggestion is opening a dedicated thread where we can discuss it publicly.
  • Like
Reactions: usm
Whisp3r
The learning process continues :cool: I wish I had some spare time to take the camera out! This one was shot a couple of weeks ago in my town, Gent, Belgium. Around four o'clock I think.
In the photo: the central bus station at Gent-Sint-Pieters (the main train station), and the Flemish government building.
Arca-Swiss RM3di, Phase One IQ4150, Schneider-Kreuznach 43XL.
guphotography
What a striking shot, Carlos!
I wonder, if it is possible, to position camera further to the right, so the canopy on the left does not clip the bottom of the window facade on the building to the left, then use shift to bring the mass to the centre of the frame?
This is the magic of tech cam, allowing you to manipulate composition in ways no other digital system can, such a liberating working method.
Whisp3r
Thanks Gunner!
I see what you mean, an added bonus could also be that the side of the tall building will be more prominent. It's a three minute walk from my home so I will probably revisit the location sooner or later and see what happens if I move to the right. I've been eyeing a brutalist structure as a potential subject as well but I'm waiting for the right lens to show up at my doorstep :cool:
I'm beginning to grasp the tech cam advantages, but I'm still thinking and visualizing in a simple, straight-forward manner, e.g. place the camera in accordance to what I see right then and there, and not in accordance to what I could potentially see if I manipulate the composition.
shfoto
A piece of mural art from the Ukrainain artist Olga Sabadin. Taken at an abandon cellulose production site in Switzerland. The artist has a favor for colorful pictures where flowers play an important role. Quite a contrast to the current situation in the Ukraine...
Cambo 1600 | IQ3 100 | SK 60xl two images stitch | f11 | 1/30 s
diggles
This month, my wife and I took our moms to Norway. Both families are of Norwegian descent, and our moms always wanted to visit. I almost left my tech camera behind but decided to bring it. In May, daylight lasts from early morning to late evening, so I knew I could go out on short excursions.
I couldn't find a spot to capture the entire cityscape without the bridge, so I decided to make the bridge a central focal point of the scene. At first I wasn't sure, but it is really growing on me.
Arca Swiss Rm3di + Rodenstock 50HR + 2.25x1 Ratio (2 image stitch, 15mm left right plus 5-10mm of camera fall)
Barcode from Akrobaten Pedestrian Bridge by Warren Diggles, on Flickr
This image highlights the buildings that are on the right.
Arca Swiss Rm3di + Schneider 120 ASPH + 65x24 Ratio (2 image stitch, 15mm left right plus 10-15mm of camera fall)
Oslo Cityscape - Barcode Right by Warren Diggles, on Flickr
diggles
It's surprising how many people stop to talk when they see the technical camera. While setting up this shot, someone parked illegally on a busy street just to chat for 10 minutes. I nearly missed making this image before the light inside the building got too bright. Lol!
Arca Swiss Rm3di + Schneider 120 ASPH + 16x9 Ratio (2 image stitch, 15mm left right plus 10-15mm of camera fall)
Oslo Opera House at Dusk by Warren Diggles, on Flickr
